Question about Jensen 143307 Remote Control
How to switch between tv and vcr dvd or wii?
I have my remote prorammed to the dvd and tv but cannot actually switch the input so can't play my Wii anymore or watch DVDs the instructions are extremely unhelpful and say nothing about this.
  • Steffany Oct 31, 2008
    My french is not so good could you please put it in English????
Bonjour j ai le meme remote que la photo ici Jensen ,,, avec le boutton orange, j ai perdu le code pour la television et celui du VCR,,,comment je fait pour le recuperer j ai pas mon livre non plus tout perdu en demenageant et le tout es encore neuf ma television es une Memorex mon VCR un Sanio pouvez vous m aider svp merci ,,,, mon adresse mail,( )
Posted on Oct 30, 2008
  • passionflake Nov 08, 2008
    I lost the codes, for my remote to the tv and dvd, my tv is a memorex my dvd is a sanio, can you help please thank you
I have a panasonic 1080p hd tv, a samsung dvd/vcr,nintendo wii and a bt vision + box, how do I connect the nintendo wii?
if your dvd vcr has an rca input and output try going into it with the wii and out to the tv. Unfortunately mine does not have input only output and I have to swap the rca plugs on the back of the tv. If you still need help I would need to know all the connection types you have on each product to set up a pattern.
Nov 22, 2011 | Nintendo Wii Console
We have a Wii that plays through a Magnavox MWR10D6 DVD Recorder. Currently we can play a DVD in the recorder and the Wii activated and we can hear it working but it will not show on the TV screen. The...
Assuming that you plugged the video cable from the Wii into the "VIDEO IN" connections on the Magnavox, you need to do two things:
1) go into SETUP and make sure the inputs are set to regular/composite, NOT S-Video
2) use channel -/+ on the Maxnavox remote to select the correct input
Feb 18, 2011 | Philips Magnavox MWR10D6 DVD Recorder
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
Switching to play video games--how do I do it?
You are going to have to order a origanal remote that came with the TV to do this because the universal remote does not have the game mode feature! Go to to order yours!
Please rate my answer and help keep this site FREE!
Thank You!
Jan 02, 2009 | RCA Universal Remote Control
Hooking a Wii to Dish Network reciever(not a hd tv)
It sounds like you have a pretty new TV. This means that there should be multiple AV jacks in the back for setting up your many components. Plug in the receiver into #1, the Wii into #2, and any other equipment you may have (DVD, VCR etc.) in the same way. You should then use the original TV remote to switch between Video 1, 2, 3 and so one for each compnent you want to use. The button on the remote will be labeled video, tv/video, input select, or input, something like that.
Hope this helps!!
Dec 29, 2008 | RCA HD52W59 HDTV Projection Television
Wii has no color
Are you connecting you Wii to a progressive scan TV input (2 for audio (red)(white), 3 for video (yellow)(blue)(red)?
It's possible you have the red audio and red video inputs switched.
If you have the regular AV-Cable (2 for audio (red)(white), 1 for video (yellow)), and your TV has 5 inputs (progressive), look for the 3 inputs (2 for audio (red)(white), 1 for video (yellow). If it doesn't, connect it to a VCR and run the Wii through the VCR input.
Dec 25, 2008 | Nintendo Wii Console
How do you hook up a wii to this thing?
ok u can hook it up though a dvd player if ur tv wont support it make sure ur on the right channel though
Dec 25, 2008 | EA Sports Tiger Woods PGA Tour 08 for...
No remote control signal and need to change input
use the channel up/down buttons on the front of the TV until you hit AV1, AV2, etc.
Dec 04, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Can hook up my wii to this tv
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most televisions or video cassette recorders (VCR). First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well.
  • Audio/Video (AV) inputs are located on the front or back of the TV or VCR.
  • They are smooth silver posts with the inside showing a color, usually red, white and yellow.
  • Look for inputs marked Audio and Video IN.
  • The image on the left features stereo audio inputs. Some televisions have only one audio input. Click here for help setting up a mono audio connection.
  • Do NOT connect your system to anything marked OUT.
Where do you have these inputs?
Additional Options:
Connecting to a Television
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setuptvav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
    Yellow = Video Input
    White = Audio Input Left (or Mono)
    Red = Audio Input Right
    Interested in playing your games in Dolby Pro Logic II (simulated surround sound)? Click here setup information.
  3. Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
    If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
    Still can't find it? We have compiled a list of known input selects for many popular brands. Click here to see our list.
    Go to Next Step (Set Up of the Wii Remote) >
Connecting to a VCR, DVD-R, Cable Box, etc.
    In order to connect a video game system through a device such as a VCR, DVR, cable or satelite box, it must have Video and Audio "inputs." While most VCRs and VCR/DVD combos have these inputs, other devices typically have "Outputs" which will not work for playing your Wii console. Please verify the device you are attempting to use has these holes.
    While many cable/satelite boxes and DVRs may have "inputs," accessing them can be difficult. Please consult the instruction manual for the device you are connecting to, for more information.
  1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console. setupvcrav.gif
  2. Insert the RCA plugs on the Wii AV Cable into the input connectors on the VCR. Make sure you are plugging the connectors into the holes labeled"Input" or "In". Holes labeled"Output" or "Out" will not work. Plug the colored connectors into the following inputs:
  3. Once the cables are inserted and the Wii is powered on, put your TV on the channel you use to watch movies (usually channel 3 or 4). Put in a video tape and play the movie. When you see the movie playing, press stop (do not power off the VCR!) and proceed to the next step.
  4. You will now need to find the Input Select for your VCR. This is usually a button on the original remote control that is labeled Input Select, AUX, Input, EXT, Line In, or a high or low channel. For more information on locating your input select, click here.
Nov 26, 2008 | Video Game Consoles & Games
Hook up the Wii
If you have the remote for the TV, it should have an input button on it that would change the video mode. If you have a universal remote, often the tv/vcr button will do that function on the newer model TVs.
Good Luck
May 22, 2008 | Sanyo DS31590 31" TV
Jensen 143307 Remote Control Logo
1,074 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
