Question about Sony VAIO VGN-N250N/B Notebook
Heatsink and fan
Does the heatsink and fan play a part in the opperation of the comupter system
  • Morris Hirakawa
    Morris Hirakawa Oct 25, 2008
    thanks joe so this could be reson my computer will not turn on ?
  • Sony Master
  • 4,338 Answers
Yes. A major part! The heatsink and the fan keep your processor cool. Without them, the laptop will overheat and shutdown completely.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 25, 2008
Alert! heatsink not connected and system halted
well YEAH! the cpu has overheated because the heatsink and/or fan over the cpu has to keep it cool. if it overheats(easily done), your system will stop and it won;t start if the fan does not spin. fix the fan/heatsink. it possilby could have killed the cpu too? not sure.
Nov 18, 2013 | Dell OptiPlex GX620 PC Desktop
My system is shutting down and restarting and it shows system shutdown by thermal
Hi:
When you have a thermal shut down, the first thing to check is the Heatsink/fan assembly. When you computer is cool, open the side panel, and power up the computer, and make sure the fan is spinning on the processor. If it is, observe the interior of the computer, and see if there is alot of dust and lint build up around the fan assembly. Obtain some heatsink compound, and carefully remove the clip or bracket that holds down the heatsink fan assembly. carefully clean off the bottom of the heatsink, and the top of the processor, and reapply heatsink compound in a thin layer to each surface, and reattach the heatsink/fan assembly, after you have cleaned it up. this should take care of your problem.!
Sep 21, 2010 | Intel D945GCCR Motherboard
System just stops playing and 2 red lights come on
Your system is overheating.
Check whether the fans are running. If not, that's the problem, check whether they are jammed or faulty (replace, check power).
If they are running, then take the 360 apart completely, take the motherboard out of the case. Remove the heatsink (the lower one). Use rubbing alcohol to remove residual heatpaste from the heatsink bottom and from the GPU (the thing that the heatsink was covering).
Reapply (thinly but completelty) GOOD thermal paste (e.g. Artic Silver nr 5). Replace the heatsink by either using the xclamp or use washers and bolts/nuts (google for x-clamp replacement) while you're at it.
Or take it to someone who can do this for you :) (I'm in the Netherlands, but otherwise I'd be happy to help you out (www.allsystemsgo.nl).
Jun 16, 2010 | Microsoft Xbox 360 Console
Overheating hp compaq 6735s
The overheating problem can be caused by a faulty fan and or dust clogging the fan and heatsink assembly. If the fan deos not spin freely then it is faulty, also loosen the dust and vacuum the dust from the fan and heatsink.
Aug 07, 2009 | HP Compaq 6735s Notebook
A/c for honda 2000 blows cold but has erratic high pressure readings very high and very low readings on low side
evacuate system and refill to proper spec for r13a refridgent may not have proper levels. check cooling fan opperation with engine running cooling fan should be opperating while a/c compressor is engaged. if all theese check out good has blockage in system
Jul 31, 2009 | 2000 Honda Civic
When i scan mycomputer then it keep siren continuously
The sound you are hearing is a warning that the CPU is over heating.
Try cleaning the CPU fan & the heatsink the fan is connected too.
If you built the system did you add thermal grease between the heatsink & CPU?
It is also possible the thermal grease has dried up & is no longer allowing the heat from the CPU to transfer to the heatsink. It may be time to replace the heatsink assembly.
If your over clocking the CPU reset it to normal.
Luck!
Mike
Jun 02, 2009 | Abit IC7-G Motherboard
Looking for cpu fan or combo heatsink for a foxconn mother board
CPU heatsink/fans are usually sold as a unit at Newegg.com, tiger.com as well as al other computer supply places. Fan and heatsink are specific and  must match CPU and socket.
Jan 17, 2009 | Coolmax CPU Fans CPU Fan
Vista 64 shuts down while playing games
Check for overheating problems
Check all fans including power supply one
Then remove fan from heatsink and clean out all fluff and dust
Vacuum out case all vent holes ans case fans
When playing games either CPU or Video card getting hot and closing down to protect system
Oct 23, 2008 | AMD ASUS A7V8X-MX ALL IN ONE MOTHER BOARD...
ASUS NCT-d
Hi, have you tried removing the CPU and using a Air Jet Spray can to clean all contact pins and pin holes? The problem sounds like a loose chip. So also check all on board chips are seated, including RAM chips. Air spray can be bought from most Computer stores. Goodluck mistyman
Sep 09, 2007 | ASUS NCT-D (90MSV430G0UAY) Motherboard
Sony VAIO VGN-N250N/B Notebook Logo
66 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
