Question about Wowwee Alive Cubs Lion Cub Wow Wee Robotic Toy
How to fix wow wee alive lion cub new batteries and nothing
Put new batteries and does not work
STOP CATS WEEING IN MY HERB GARDEN
Visit your local zoo and get some lion/tiger/cheetah pooh and put some in your garden and that will stop them. Simple mirrors placed around the garden also works quite well. I use water filled lemonade bottles
Jan 19, 2017 | Cats
I was mowing I have a cub cadet series 1000 was running fine all the sudden shut down and will not start acts like it has no connection. Battery is new, but still cleaned terminals. Turn key nothing
Make sure your new battery is charged up first. New batteries will die sometimes. Make sure your cables are tight and clean and your starter could be at fault if all that work it won't turn over. Make sure your engine is not seized as well.
Jul 21, 2015 | Cub Cadet Garden
We have a Wow Wee roboraptor and have lost the battery cover. Where can we get a replacement?
http://www.wowwee.com/en/products/toys/robots/robotics/robocreatures/roboraptor
Jul 03, 2015 | Toys
I was using the mower and it just quit, will nor even turn over, nothing works
A push or riding? Hit anything? a few things I need to know to give honest advice...
May 26, 2015 | Cub Cadet Garden
Non working wowwee lion cub
The Cub's quick power button is located on his right ear. Once you set (rather than switch) the power switch to Normal setting, your Cub should automaticallly be in normal play mode when turned on. To turn him on after he powers down and enters Sleep Mode: • Ensure the main power switch is set to Normal. Locate the quick power button and press it once.NOTE: If you press it more than once after switching it to the Normal setting, you will be toggling the volume levels.To turn him OFF: • Locate the quick power button and hold it down for about 3 seconds.
May 12, 2012 | Wowwee Alive Lion Cub Full Size
Is the mouth supposed to open on its own? if not how are you supposed to open it as i am just pressing under the mouth but its not very easy for my child to do. thanks
They way these stuffed animals function is by sensors. So when you pick them up by the nap of the neck the legs are suppose to go link. And when you pet the their eyes and mouth are suppose to open. If left alone it will go into sleep mode. Put it on it's back and it acts playful. Make sure the batteries are fresh. Use alkaline batteries when possible as motorized toys such as this are heavy on batteries.
Regards, Tony
Apr 14, 2011 | Wowwee Alive Cubs Mini Lion Cub Wow Wee...
Dont know How to operate Wowwee Alive Polar Bear Cub - 9010
http://www.wowwee.com/static/support/alive-baby-animals/manuals/Alive_Cubs_Manual.pdf
There's the manual for all the Alive Animal cubs. Hope this helps you out :)
Jul 29, 2010 | Wowwee 9010 Alive Polar Bear Cub
Engine wont start after charging, will start with a jump. The pto will not engage
Sounds to me like you need to scrape the **** off of the battery cable ends and the battery posts,or you just have a battery that has sulfated and will not take a charge.Repairing the connections or installing a new battery should fix the starting problem and because the pto is engaged with electricity it should fix that too.
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet lt1045 series and I cant get it started
check starter-the starter gear may be stuck or spring may be broken -new doesnt mean free from defects--if starter before working on or removal of parts notify place of purchase should be covered under warranty
Mar 13, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Wowwee Alive Cubs Lion Cub Wow Wee Robotic Toy Logo
73 people viewed this question
Top Wowwee Toys Experts
Michael Vincent Cruz
Shekar Avadhani
Tom Chichester
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
