Question about Hitachi DS18DL 18V Liion Cordless Drill Driver
I;d like to purchase a housing for a Hitachi DS18DL can you help?
Snapped handle in normal spot above trigger
  • Bob Butler Feb 17, 2012
    Drill casing is available on US sites and I had 1 replaced under warranty last year, they are available just where abouts is the issue.
    I live in Australia, parts available here?
3 Suggested Answers
  • 107 Answers
SOURCE: Hitachi DS18DL drill quits under load
sounds like your battery is either shorted out or out of charge
Posted on Jun 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: trying to remove a jacobs key less chuck 500
It twists off counter clock wise. The best way I have found to remove the chuck is to stick a screw driver into the chuck, tighten the chuck, hold the screw driver in some type of vise and run it all full speed in reverse
Posted on Jan 02, 2010
Hitachi ds18dl wont charge battery
Please check the LED status of the charger to find out what the reason and solve it.
Apr 28, 2014 | Hitachi DS18DL 18V Liion Cordless Drill...
Rear door latch is broke
I had to do this, too... Mine cost me $70 at the local dealer (they even got it in the same stock paint color). Tip: buy a few of the inexpensive replacement plastic pins for your inner panel when you buy the handle housing, as they tend to break easily. You can pop the old pins by sticking a narrow straight screwdriver or a butterknife under the panel near them and twisting... once it's off, the screws for the old handle housing are fairly easy to spot (just remember where the housing bolts on from the exterior are located). Now that those are off, realize that the thing is probably hanging from your trunk by the wires connecting the license plate lights and the handle, itself They can be removed from the old, broken housing with a phillips #2 (normal size) screwdriver, and then the wires have a quick-disconnect so that you can pop the lights and the handle off w/o cutting the wires. Pop them off, slide the wires through your new handle housing, and screw them back on. then slide the handle housing into position (lining up the screws that are molded into the housing with the adjacent holes). You'll have to kind of hold it in place as you raise the trunk hatch to full open position, but once it's up, gravity is your friend. Use the screws that were holding the parts from the broken housing to re-affix the new one, and you're done.
Feb 29, 2012 | 2006 Scion xB
Hitachi DS18DL stopped during drilling.
it sounds like a gearing problem simply take it back to where you purchased it and ask for a replacement or a refund
Jul 24, 2010 | Hitachi DS18DL 18V Liion Cordless Drill...
Have a hitachi cordless drill that the chuck has become stuck and cannot remove drill bit
Soak it with WD-40 and let it set so the lub runs down into the chuck and then try...
heatman101
Mar 21, 2010 | Hitachi 18V Lithium Ion Cordless Hammer...
I have a three year old hitachi dv18dl cordless hammerdrill. The low gear is stripped and the trigger is intermittant. I tried taking it apart but saw nothing obvious. Any ideas on what to do or where to...
http://www.ereplacementparts.com/hitachi-dv18dl-18v-30ah-lithium-ion-cordless-hammer-drill-parts-c-7927_13467_13346.html
Here is the diagram for the drill. I would replace the gearbox and dc control switch. But it may be cheaper to buy a new drill.
Nov 25, 2009 | Hitachi Dv18dl 1/2 18v Cordless Hammer...
Jun 22, 2009 | Hitachi 18V Lithium Ion Cordless...
Trigger housing is worn and won't permit contact
Yes...try Delco cleaning systems....www.dcsl.com for a selection of many trigger units.
Apr 22, 2009 | Coleman Garden
Hitachi DS18DL 18V Liion Cordless Drill Driver Logo
79 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
