Aeg oko lavamat 72620 door seal is twisted - can it be realigned or must it be replaced
5 Suggested Answers
  • 641 Answers
SOURCE: AEG Lavamat 72620 door does not open
It seems that your problem is with the lid switch and it should be replaced. The switch is inside the washing machine main housing near the door frame. You have to raise the top of the washer to get to the switch. Good luck!
Posted on Sep 06, 2007
apart4u
  • 213 Answers
SOURCE: advise correct procedure for replacing door seal on aeg lav 72620
Follow these steps to replace your door seal:
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
SOURCE: how do i reset a aeg oko lavamat 72620 washing
how to make reset to AEG OKO lavamat 61600
Posted on Nov 14, 2010
  • 6277 Answers
SOURCE: mijn AEG oko lavamat 72620
AEG code 9- tacho/motor fault ;-0(
Sorry,
John C
Posted on Mar 19, 2011
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Mijn AEG oko lavamat 72620 meld code 9
Sorry,
John C
Mar 19, 2011 | AEG Washing Machines
What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Jul 14, 2010 | AEG Lavamat 72640 Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
Aeg oko_lavamat 508- not enough water
Have law level water problem in my clothes washing AEG Lavamant OKO 508.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
Apr 09, 2008 | Washing Machines
Sep 05, 2007 | AEG Lavamat 72640 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
