Question about MTX RFL1200D 1Channel Car Amp
YELLOW LIGHT LIGHTS ON MTX RFL1200D - MTX RFL1200D 1Channel Car Amp
I have an MTX audio JH 300 amplifier. When I turn the power off from the amp the yellow light comes on and stays on continuously. after about 15 minutes listening music amp shuts off, why
the light stays on because the amp is still storing power. it only turns off when the capacitors on the inside have drained off all the extra power
Oct 15, 2015 | MTX Car Audio & Video
My brake light on my dash is constantly on
Look beneath the dash panel at brake pedal assembly. You should see the brake light switch, which completes a circuit to brake lights when you step on the brake pedal. Its likely this switch is malfunctioning. The circuit is closed (power to brake lights) when the brake pedal is not depressed. The circuit is suppose to be open (no power to brake lights) when your foot is off the brake pedal. Unplug the wire connector and unscrew to replace this brake light switch.
As for the knocking sound, is it when the vehicle is in motion? Or even when the vehicle is stopped and idling in park?07060338-db0d-4c14-8a08-ace846c99fb4.jpg
Nov 29, 2013 | 1995 Mazda 626
Not a green light comes on like normally... a yellow one comes oh
could be the wires is bad or someplace the power wire is grounding out or the fuse or fuses is blown. or could be not enough voltage but highly doubt it.
Jul 28, 2010 | MTX Thunder 4250D Car Audio Amplifier
Yellow circuit protection light
Please see my tip HERE regarding Protection Mode for Car audio Amplifiers.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 18, 2009 | MTX (TC4004) Car Audio Amplifier
MTX thunder 304 4ch red amp light comes on but no audio have triple checked all connections and they seem alright
if the lights on and there is no sound it's either a cd player issue or your rca issue or the inputs for rca's on the amp are no good. or you have your subs wired at a wrong load to your amp and it is in a constant protection to avoid burning up.
Jun 09, 2009 | Car Audio & Video
No LED power lights go on
the light with the power light(middle) is a blue/purple faint light try checking it out at night.The squiggy(as heat waves) will only light when the amps shuts down due to thermal protection(wait for it to cool). The bolt/yellow (short circuit) will light when there is an electrical overload in any of the wires(check +ve leads).
May 26, 2009 | MTX JackHammer JH202 Car Audio Amplifier
MTX 1501 D
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Apr 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Oct 18, 2007 | MTX TA4501 Thunder 4501 MonoBlock Car...
MTX RFL1200D 1Channel Car Amp Logo
107 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
