Question about Porter Cable Saws
How to replace lock plate on porter cable 423mag saw
I can't figure out how to remove the ss/a-jackplate assembly to replace the lock plate that locks the blade for removal???
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: The saw blade on my Porter cable 423mag saw is jammed tight.
Unless you can get a wrench on it I can't see anything else on the breakdown. You are aware that the knob is Left Hand thread I hope.
Posted on Mar 22, 2009
I have a porter cable 16' variable scroll saw. the tension knob on the back will not stay in place, hence making the blade loose, how can I fix this.
Try some blue LocTite thread fastener. It's an anaerobic-hardening resin. Remove the knob enough to get a drop onto the threads, then snug it up. Going forward, repeat as necessary. Just a drop.
Better than lock-washers. Scrollsaws basically just vibrate their little blades up & down.
Mar 02, 2016 | Porter Cable Garden
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
How do u put on a saw blade for a cordless circular saw.???
First remove the battery, next make sure of the blade rotation and remove the hex bolt and OUTER flange lift the guard and put the blade on the spindle. Reinstall the outer flange and tighten the hex bolt, generally newer saws have a spindle lock to hold spindle to tighten the blade. If this is a Porter Cable like in the header you can go to dewaltservicenet.com and with your model and type number find an operators manual. Let me know if you need more assistance.
Mar 11, 2012 | Porter Cable Saws
My trusty PC 7 1/4",15 amp after many years simply stopped running .no electric/burniing smell. hoe do i diagnos burnt out motor versus cord/switch break?
Check the carbon brushes by removing the black cover on the end of the motor. The brushes should be long enough so the spring can hold them firmly against the armature. The end of the brushes should be slightly concave and smooth/shiney. If they are worn down too short or look broken and don't touch the armature replace them. If the brushes are OK, take the right half of the handle off, should be five or six screws. Look for any burn marks or melted wires along the cord and switch wires. Use an electrical multimeter set to AC in the 200V range. Plug the cord in and check for voltage where the cord goes into the switch. If no voltage, replace cord; voltage, move on. If the switch can be locked on do so, otherwise you'll have to have someone hold it on while you check for voltage on the out side of the switch. Again no voltage, replace the switch; voltage move on. If you have power going into and coming out of the switch and the brushes are OK you may have a problem with the armature or field. These have to be tested with a growler to check for shorts. Most electronic shops have one.
Sep 02, 2010 | Porter Cable 423MAG Factory Reconditioned...
Can't take off front off porter cable tiger 747 (rubber boot
Remove 2 screws from under front grip and the swivel foot should slide forward and out (might need a bit of a twist to loosen) plastic grip should now slide forward and off.
Dec 07, 2009 | Porter Cable Variable Speed All-Purpose...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
Blade won't lock.
There is a ball lock in it and you have to twist the ball lock but if the ball lock is frozen generally WD40 will help unfreeze it and work it until the ball is free and should work just fine.
Jun 09, 2009 | Saws
Mar 22, 2009 | Porter Cable Saws
Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Oct 21, 2008 | Porter Cable Saws
Saws Logo
61 people viewed this question
Top Porter Cable Saws Experts
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
