Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Linksys Cable/DSL Router model BEFSR4141
I have lost the directions to hook up the router.
  • Anonymous Jan 18, 2009
    my router won't connect automatically to the internet
I have linksys befsr41 cable/dsl router w/4 port my cable provider gave me a router that has only one internet port but i have two computers will this linksys make it able to hook up two computers? also one is a mac and one is a pc, will that have any effect on it?  also, i have no driver for this linksys, do i need one?
Posted on Jan 03, 2009
  • 928 Answers
Since you did not include the type of internet provider I cannot give you more specific instructions. Although you can refer to the links below on how to set it up. If you require further assistance just reply to this and give me the model number of your ISP and the model of your router. Also answer this question " When you plug your computer to your modem do you get online automatically or do you need a username and password"
DSL
Cable
Posted on Oct 25, 2008
  • Thomas Lim
    Thomas Lim Oct 25, 2008
    You did not add any information. how do i know what caused the problem or what else needs to be done.
AT&T just gave me a new Motorola DSL box and I can't get my router to even find the internet which is active. I can only get the router install portion to go just to where it can't find the...
First of all using the Router Install Portion try to do a 'factory reset' or a 'reset to default'  - wait for a reboot to see if any change occur.
Next try to use the cable between your Moto Box and your LinkSys Box in a different port on the link sys. It may sound silly, but it can work very well sometimes.
Nick
Sep 03, 2009 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Linksys routetr problem
HI,
The problem can be caused, because of two reasons, one the router profile on the computer has got corrupted and second the router itself. Have you tried resetting the router to factory defaults.. Caution: all wireless security settings and user name and passwords would go back to factory defaults.
1.Disconnect all cable from the back of the router.
2. Shut down your computer and the DSL box
3.Press the reset button, using a paper clip at the back of the router.Keep it pressed for 5 seconds
4. Disconnect the power cord to the router
5. Switch on the Dsl box, wait for the lights to stablize
6. Reconnect the interenet cable and the power cable to the router and power it on.
7 Let the lights stabalise on the router and power on the computer.
Check if that resolves the problem, if not we might need to update the router.
Thanks
Proton
Oct 18, 2008 | Linksys BEFW11S4 802.11b Wireless...
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Just connected to cable modem from dsl
two things are you hooked up from the dsl to the router via Ethernet or usb is so check the settings in the router, it should be auto, so it could choose but lets not assume anything.may sure dhcp client or server is enabled on the router, if not it would not pick up the ip adddress from dsl.
Is the mac address of your computer hardcoded to your dsl, if it is then you would have to clone your pc mac to the router for it to work.
If this is not the case, try a different router if it works the router is faulty. if that does not work plug the dsl directly to the pc and go to start, run type ipconfig /all if you recieve an ip address and you can see a dns address from your isp and you can go to the internet, then the problem is your router, if not the problem is with you isp dsl, please contact them. was this helpful let me know.
Jun 03, 2008 | Computers & Internet
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Westell router modem hook-up
No. That device is a DSL gateway. It is exclusive for dsl connection.
You can use a Linksys WCG200.
Mar 23, 2008 | Westell Wirespeed VersaLink...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
133 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
