Question about Kwikset UltraMax Powerbolt 1000
Putting in code locks door pressing unlock locks door
Will not reset
  • 963 Answers
First, remove the cover on the inside of the Powerbolt . On the right-hand side under the batteries, you will notice that it says" Door Direction Jumper". If the jumper is mounted on pins 1 & 2, then move it to pins 2 & 3. Or if it's already on @ & #, move it to pins 1 & 2.
Posted on Feb 17, 2012
How do i change the code on a s25e digital safe i cant find the book
if its like my old woolworths one, open the door and press a red reset button on the inside of the door, close the door and dont lock, put in the 4 numbers u wish a press a A button on the keypad, or whatever ur enter button is, then lock it, then press the 4 numbers again and the A button or enter, a light should stay on and unlock :)
Feb 21, 2011 | Safe International Electronic Gun Safe...
I have an old woolworths workshop safe with no keys or code
without keys not sure, but with mine i had it open pressed the red reset button on the bottom of the door, closed the door not locking it, put in my 4 digits pressed A at the bottom of keypad and locked it with the light on, to unlock put the 4 numbers in and A and unlock while the light it lit.
Jan 30, 2011 | Safe International Locks & Locksmithing
Wrwent to unlock my 1996 Hona accord with the remote and noticed the light was on. It wouldn't unlock the door . Put in a new battery and that didn't work. Do I need to reset the alarm? If so, how do I do...
Remote Transmitter Replacement (Wagon)
Use the following procedure when replacing one or both remote transmitters:
  1. Open the driver's door.
  2. Press and hold the driver's master door lock switch down in the UNLOCK position.
  3. Quickly insert and remove the key from the ignition switch five times, then insert the key the sixth time, and leave it in the ignition switch. (This routine must be done within 1O seconds.) All the doors will lock and unlock to indicate that the control unit is in the program mode.
  4. Press either button on the replacement transmitter. All the doors except the driver's door will lock and unlock to indicate that the control unit has accepted the transmitter into its memory. If either transmitter button is pressed again, all the doors will lock and unlock.
  5. To program a second transmitter, press either button on that transmitter. The doors should lock and unlock as described in step 4.
  6. Release the driver's master door lock switch.
  7. To exit the program mode, close the driver's door or remove the key from the ignition switch.
Dec 18, 2010 | Honda Accord Cars & Trucks
I want to change the key guard code of my nokia1616. how? i don't want it to be just 12345
How do I change the code that locks my phone?
Press "Menu"
Scroll to Settings, press "Select"
Scroll to Security settings, press "Select"
Scroll to Change access codes, press "Select"
Scroll to Change security code, press "Select"
Enter the current security code, press "OK"
Enter a new security code, press "OK"
Re-enter the new security code, press "OK".
Nov 07, 2010 | Nokia 1616 Cell Phone
Keypad door lock does not work..?
it's in owner manual. But, first you have to enter your original code and it must work. then you press the 1 button and then enter a new 5 digit code, then press the 1 button again.
Keyless Entry Keypad To unlock the driver front door (20124) , and disarm the anti-theft alarm control (19A366) , (if equipped):
  • Enter the permanent factory code.
  • Enter the owner's alternate code.
To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment. To unlock the luggage compartment door (40110), press the 5/6 button within five seconds of unlocking driver or passenger door(s). To turn on the courtesy lamps and light all illuminated components, lift either front door handle (22404) or press any button on the keyless entry keypad (14A626) . To lock all doors, press the 7/8 and 9/0 buttons at the same time with all doors closed. (It is not necessary to enter the key code first.) This will turn off courtesy lamps and arm anti-theft alarm control (if equipped). To program an alternate code:
  1. Enter the five digit permanent entry code into keyless entry keypad .
  1. Within five seconds of pressing last button of permanent code, press the 1/2 button within five seconds of pressing the last button of the permanent code.
  1. Enter any alternate five digit code within five seconds of pressing 1/2 button.
    • Enter a sixth digit as follows to indicate operator's memory seat setting to be set by alternate code:
      • 9/0 — no memory recall
      • 1/2 — memory seat position 1
      • 3/4 — memory seat position 2
      • 5/6 — memory seat position 3
    • After successful programming, the doors will signal by locking and then unlocking.
  • Keyless Entry Keypad Does Not Work Properly
  • Circuit.
  • Keyless entry keypad.
  • Electronic door lock control processor.
  • Open Fuses:
    • Town Car and Crown Victoria/Grand Marquis
    • Power Distribution Box (under hood)- K, 40A (Maxi)
    • Instrument Panel Fuse Panel - 17 (10A), 10 (20A), 8 (15A), 5 (15A) and 4 (10A)
  • Loose Connectors
  • Corroded Connectors
  • Oct 04, 2009 | 1995 Lincoln Town Car
    Step by step reset the door remote control lexus 400LS
    1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
    2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
    3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
    4. Shut door.
    5. Open door.
    6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
    7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
    8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
    9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
    10. Close the door.
    11. Open the door.
    12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
    13. Close the door
    14. Press the lock button on the remote, the doors should lock.
    15. Press unlock button and the doors should unlock.
    Jun 16, 2009 | 1996 Lexus LS 400
    Center button unlocks insted of locks code locks insted of unlock
    Take off the inside cover and move the door direction jumper over one pin.
    Jan 22, 2009 | Weiser Lock Powerbolt 1000 Lock
    Power locks not working right
    Hey, this might work.....get in truck, close doors, put key in ignition in lock position.....hold down the door lock button on driver side door control and wait for the lock control to be displayed on the information screen(odometer read-out).....it should say like lock 1, lock 2, lock 3, lock 4.....or something, I always reset mine to LOCK 1, to do this hold the odometer reset button on dash for a sec or two til it changes settings, then release, repeat till you get to LOCK 1, then quickly press and release odometer reset button to exit program, this is the function to lock doors over 15 mph and when out of park and to unlock doors when returned to park......yours' might be set to another function number....try it out, let me know if this helps.........good luck!
    Nov 10, 2008 | 2004 Chevrolet Colorado
    Sim lock code
    *#9998*3323# phone will reset. press exit & then press 7. it will reset again .put in simcard .it will say simlock. put in 00000000 then it should be unlocked then type in *0141# & the green button and it unlocked all networks. GOOD LUCK
    Jun 23, 2008 | Samsung SGH-E370 Cellular Phone
    Kwikset UltraMax Powerbolt 1000 Logo
    155 people viewed this question
    Top Kwikset Locks & Locksmithing Experts
    Jim Thurston
    Mike
    Steve Masymas
    Level 1 Expert
    Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
