Question about Microsoft Xbox 360 Universal Media Remote
Sanyo dp42740 i need the code
SANYO DP42740 DIGITAL CONTROL BOARD , can it stop the tv from powering up .
Yes. If it has shorted component/s. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 21, 2015 | Sanyo Televison & Video
What causes the sanyo DP42740 plasma tvs green power light turn on and off?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 02, 2014 | Sanyo DP42746 42 in. Plasma Television
Where is located the fuse in a tv sanyo model No. DP42740
There are several fuses on the power supply board.
The main one is right next to where the cable from the AC connector is on the power supply.
BTW you may want to check these listings too:
http://www.coppelltvrepair.com/search?q=DP42740
(although if you are looking for a fuse that probably means totally dead TV and if that;s the case then you do not need a main board repair)
Apr 14, 2014 | Sanyo DP42746 42 in. Plasma Television
What is the display section of Sanyo DP42740
Between the front glass and the metal shield on which the boards are sitting is the display.
It is the same for all plasma televisions :-)
Feb 18, 2014 | Sanyo DP42740KNB 42 Class Plasma HDTV -...
What is the usb for on the sanyo DP42740
USB port is located on the back of unit next to the Antenna input. See page 6 of: http://us.sanyo.com/dynamic/product/Downloads/DP42740%20(355--)-25942323.pdf
Nov 27, 2013 | LG 42PX5D 42 in. Plasma HDTV
Is there a manual to explain the sanyo dp42740 remote?
Yes. You can get the tv manual from;
http://us.sanyo.com/Plasma-Televisions/42-Class-41-6-Diagonal-720p-Plasma
Click on the Download tab then click on the manual icon. The remote control operations are explained.
The manual is in PDF format so you will need ADOBE reader to read it. Most people have ADOBE
but if not you can download the reader from www.getadobe.com.
Apr 14, 2011 | Televison & Video
Sanyo model dp42740. Audio speeds up, if I change to another channel and return, problem is gone until it does it again, sometimes it does it once an evening sometimes two or three times.
Sounds like you have a bad digital reception from the aerial. You'll either need to adjust or replace the aerial, make sure all lines are connected at the aerial point, and it's advisable to invest in a signal booster.
Nov 08, 2010 | Sanyo Televison & Video
Microsoft Xbox 360 Universal Media Remote Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
