Question about Mintek MDP-1070
Error message bad disk or no disk - Mintek MDP-1070
I dont know ,why it gives me a message no disk? what should i do ?
Posted on Sep 22, 2012
What do i do when my computer shows the message non system disk or disk error
If your hard disk can detect on BIOS Setup,There is a problem on your hard disk. Whether the installed OS is corrupted or the hard disk itself have bad sectors. Sometimes Master Boot Record (MBR) issue. Try to make fresh install of OS
Feb 23, 2013 | HEWLETT-PACKARD 620 XT964UT Notebook PC
What does error code 2881 mean?
Error 281 is a disk recognition error, bad disk, scratch on disk or disk contains moisture (dry it)
Try
1.- get out and reload the disk
2.- Clean the disk for Dust / scratch
3.- clean pick up lens (with a soft clooth or a piece cotton
4.- Replace the disk and check if the error message continue.
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Hitachi DZ-MV230A DVD Camcorder
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
Oct 14, 2010 | Acer Aspire 5315 Notebook
While i was trying to setup vista in my computer its shows me KARNEL_DATA_INPAGE-ERROR HOW CAN I SOLVE
KERNEL_DATA_INPAGE_ERROR
Explanation:
This Stop message indicates that the requested page of kernel data from the paging file could not be read into memory. This Stop message is usually caused by a bad block (sector) in a paging file, a virus, a disk controller error, or failing RAM. In rare cases, it is caused when nonpaged pool resources run out. It is also caused by defective hardware.
User Action:
If the I/O status is C0000185 and the paging file is on a SCSI disk, the disk cabling and SCSI termination should be checked for problems. Check your computer for viruses, using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. An I/O status code of 0xC000009C or 0xC000016A normally indicates the data cannot be read from the disk due to a bad block (sector). If you can restart the system after the error,Autochk runs automatically and attempts to map out the bad sector. If Autochk does not scan the hard disk for errors, manually launch the disk scanner. Run Chkdsk /f /r on the system partition. Restart the system before the disk scan begins. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r . Caution: If your system partition is formatted with the FAT file system, the long file names used by Windows 2000 can be damaged if Scandisk or another MS-DOSbased hard disk tool is used to verify the integrity of your hard disk from an MS-DOS prompt. (An MS-DOS prompt is typically derived from an MS-DOS startup disk or from starting MS-DOS on a multiboot system.) Always use the Windows 2000 version of Chkdsk on Windows 2000 disks. Another common cause of this Stop message is failing RAM. Run hardware diagnostics supplied by the system manufacturer, especially the memory scanner. For details on these procedures, see the owners manual for your computer. Check that all network adapters in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure network adapter contacts are clean. Check the System Log in Event Viewer for additional error messages that might help pinpoint the device causing the error. Disabling memory caching of the BIOS might also resolve it. Finally, if all the above steps fail to resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can also cause this error. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Dec 03, 2009 | Compaq Presario Notebook
Lost of Hibernation
User Action:
If the I/O status is C0000185 and the paging file is on a SCSI disk, the disk cabling and SCSI termination should be checked for problems. Check your computer for viruses, using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. An I/O status code of 0xC000009C or 0xC000016A normally indicates the data cannot be read from the disk due to a bad block (sector). If you can restart the system after the error, Autochk runs automatically and attempts to map out the bad sector. If Autochk does not scan the hard disk for errors, manually launch the disk scanner. Run Chkdsk /f /r on the system partition. Restart the system before the disk scan begins. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r . Caution: If your system partition is formatted with the FAT file system, the long file names used by Windows 2000 can be damaged if Scandisk or another MS-DOSbased hard disk tool is used to verify the integrity of your hard disk from an MS-DOS prompt. (An MS-DOS prompt is typically derived from an MS-DOS startup disk or from starting MS-DOS on a multiboot system.) Always use the Windows 2000 version of Chkdsk on Windows 2000 disks. Another common cause of this Stop message is failing RAM. Run hardware diagnostics supplied by the system manufacturer, especially the memory scanner. For details on these procedures, see the owners manual for your computer. Check that all network adapters in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure network adapter contacts are clean. Check the System Log in Event Viewer for additional error messages that might help pinpoint the device causing the error. Disabling memory caching of the BIOS might also resolve it. Finally, if all the above steps fail to resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can also cause this error. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
Nokia n95 8gb disk error problem
dear, there is a 8gb hard drive in ur phone now its gvng u disk error.to sort out this u have to format ur phone hard drive because a bad sector has been formed due to overloading or virus which can be removed by formatting
Jul 03, 2009 | Nokia N95 Cellular Phone
Error message when put in isp disk saying cant find hardware
YOR ROM DRIVE IS BAD,,GET A NEW ONE AND REINSTALL WINDOWS
May 15, 2009 | Computers & Internet
Updated navi dvd, error message
Sounds like the CD driver is bad.
Oct 14, 2017 | 2004 Acura TSX
My dell 8400 displayed this error message 00f0: 136c and 00f0: 0242 What can I do. Thanks
This message is likely to be due to a segment error on your hard drive.
Checking /correcting disk errors
You can use the Error-checking tool to check for file system errors and bad sectors on your hard disk Open My Computer and then select the local disk you want to check.
  1. On the File menu, click Properties.
  2. On the Tools tab, under Error-checking, click Check Now.
  3. Under Check disk options, select the Scan for and attempt recovery of bad sectors check box.
To open My Computer, click Start, and then click My Computer.
  • All files must be closed for this process to run. If the volume (drive) is currently in use, a message box will appear prompting you to indicate whether or not you want to reschedule the disk checking for the next time you restart your system. Then, the next time you restart your system, disk checking will run. Your volume will not be available to perform other tasks while this process is running.
  • If your volume is formatted as NTFS Windows automatically logs all file transactions, replaces bad clusters, and stores copies of key information for all files on the NTFS volume.
Mar 31, 2009 | Microsoft Windows XP Home Edition
Mintek MDP-1070 Logo
48 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
