Question about Tools & Hardware - Others
My senco 1/4" crown air stapler would not drive a staple & now leaks air constantly
Had been in storage a while, fired intermittenly, then did nor fire, and then began to leak ait constantly. It has always been oiled before using
  • 885 Answers
It sounds like you have broken or damaged o-rings inside the gun and the only repair is to replace them. Senco does make kits to rebuild most of their guns. Go to http://www.senco.com/ and click on 'Parts Charts' at the top of the page then find your model. The PARTS GUIDE will list a rebuild kit if one is available. The part number will start with YK followed by four numbers. If there isn't a rebuild kit available for your gun, you'll have to order each o-ring seperately. All o-ring part numbers start with LB.
Posted on Feb 20, 2012
  • 425 Answers
It is always best to list which model you have. The older Senco SKS for instance used a head valve that is only available as an assembly. They are not serviceable other then replacing the complete assembly. And while this tool was listed as an oil-less tool it is still a good idea to put a small amount of oil in there. The trigger valve for those was also replaced as an assembly. On many of the various makes and models of air nailers and staplers it is not uncommon for the head valve to get stuck if it has sat for awhile. They will usually shoot once then start leaking from the exhaust port on the head.
Posted on Mar 06, 2012
3 Suggested Answers
comax
  • 154 Answers
SOURCE: Senco narrow crown Stapler Piston will not go back
There is a spring and piston in the back cap of the nailer, this must be free moving and not sticking. If it is sticking it will cause the problem you discribed. If that looks ok you probably should install an o-ring kit and that should solve the problem. A Senco service center will carry the proper parts.
Posted on Apr 16, 2009
ariftariq
  • 91 Answers
SOURCE: the problem i'm having is with a senco sn 41 stapler the driver wont fully return to the top
Hello try to put some oil in the connection of top and bottom may be this might help. please rate my comment
Posted on Nov 21, 2011
What is wrong with my Senco pneumatic upholstery stapler?
only a guess but is the anvil sticking out the bottom where the staples come out . if so push it up a little with a flat blade screw driver .
Feb 23, 2015 | Senco Tools & Hardware - Others
Fastener length
Senco does not make a tool with the model number STS15. They do have a SNS15 narrow crown stapler which will shoot a staple from 3/8" to 1" in length, no longer. You would need the SNS18 to shoot staples longer than 1", it can handle staples from 3/8" to 1 5/8" long.
May 01, 2012 | Senco Air Tools & Compressors
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Sns45xp senco dosent shoot anl leak air for the cap
You have worn or broken o-rings in your upper firing and trigger system. You need a Senco repair kit #YK0230 to fix your problem. Fairly easy to do, replace one o-ring at a time to make sure you get them back in place properly and use the grease in the kit liberally. Since you'll have it apart I also recommend you get Senco repair kit #YK0231 which is the lower seals and piston stop. If the upper rings are going bad the lower rings won't be far behind.
Feb 03, 2011 | Senco SNS45XP 16Gauge Construction Stapler
After shooting a staple the driver does not return up into the stapler.
obvious answers are 1. a burr on the striker, 2. a bent striker. 3. a trapped staple 4. a broken return spring. other than that I cant help you without seeing it.
Feb 02, 2011 | Senco 300120n Sksl Medium Wire Staple Gun...
Stapler will staple ok then it will jamb and break staple in half,and driver will stick but you can put driver back and will run for a short time then has same problem. It also is breaking up staples as it...
It sounds like the gun is working properly but is having feeding problems. First, make sure you are using the proper staples for your gun. Senco makes three versions of the SKS(XP) stapler: The SKS L11-17 drives 18 gauge, 1/4" staples. The SKS M12-17 drives 18 gauge, 3/8" staples. The SKS N12-17 drives 16 guage, 7/16" staples. None of them use staples over 1 1/2" long and each gun will only shoot the staples it is set up for. If you are using the correct staples make sure the rail and nose peices are clean and the feeder shoe and staples are riding freely on the rail and the feeder spring holds them firmly forward in the gun. Lastly check the tip of the driver to make sure it is square, it should not be rounded or have any chips out of it.
Dec 07, 2010 | Senco SKS 18 Gauge Stapler
Bostich narrow crown air stapler won't work
before going about rebuild get can of carburetor spray cleaner and stray the ram area lots of times the glue that holds the staples/or nails builds up and stops up the ram rod spray the rod a few times than with air hooked up dry fire if it frees up lube rod area
Jan 17, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Senco 18 ga narrow crown stapler drive pin does not return to fire position. is that a trigger issue drive pin is not broken and I put in cylinder kit last year.
Have you oiled it while in use ? You need to take the airhose off and put a few drops of air tool oil in the fitting and then try it a few times. hope this helps you
Oct 16, 2009 | Tools & Hardware - Others
I have a Senco MII Roofing Stapler and the Driver will not return what do I do?
air operated stapler/nailer. there is an air leak in the lower chamber. get an o ring rebuilding kit.
Oct 13, 2009 | Senco Tools & Hardware - Others
Senco staple fastener not firing.
Make sure you actually removed the entire broken staple and there's not a piece still wedged up in there somehow.
Try raising the air pressure up to 125 psi and plug it in and unplug it a few times. Sometimes the piston can get jammed, and a smack with the palm of your hand on the side of the cylinder will jar it loose. If that doesn't work, try pulling the trigger as you jam the nose of the gun against a soft piece of 2x4 or something, repeatedly firing and jarring the tool. If this doesn't do it, you may have to open it up to clear the jam and put it back together.
Mar 28, 2009 | Senco Fastening Systems 760102N Pro 25 Xp...
Tools & Hardware - Others Logo
436 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
