Question about Garden
Looking for a manual for my scorpion spw 6.5 high pressure washer
3 Suggested Answers
  • 1631 Answers
SOURCE: what oil should be used in the pump of a scorpion spw-2 pressure washer?
Not exactly sure of your brand of washer...
but in 'most' cases, (and found out recently, not in all cases) pressure washer pumps need a Non Foaming style of oil. This usually is the same as a NON Detergent blend of 30 weight SAE Motor Oil.
Posted on May 21, 2015
Austech scorpion pressure washer
check for blocked jet in the end of the wand ( most likely)
check for faulty pressure control valve
check that the hose is not collapsed
check that the tap is turned on to the unit
Nov 21, 2015 | Garden
What oil should be used in the pump of a scorpion spw-2 pressure washer?
http://www.ultimatewasher.com/operators-manual.htm
May 19, 2015 | Garden
Specifications- SPW-2 pressure washer
try Google and see if it lists them there
May 18, 2015 | Garden
SPW-2 WONT RUN UNLESS GUN TRIGGER IS HELD ON ?
Check the intake and discharge water lines the filter screens get clogged with calcium etc. Make sure they are clean and clear.
Jan 22, 2015 | Garden
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Garden Logo
474 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
