Toshiba satelite A200 A1I Replacement DC power jack
Hi, Im trying to put a new DC power jack on my laptop as the old one is burnt out and not giving a good connection. Im trying to replace the old standard DC jack with a radioshack coaxial size N power jack as advised by a guide I am following but the part i have orderd is a bit different to the one used in the guide instead of haveing a positive and negative connectors on the jack the one i have has three connectors a positive and two negatives so i am not sure if its ok to use. So basically the connector i have has three connector points to solder the wires onto and the one in the guide only has two so im not sure if its ok to use this power jack? If any one could help me out with advice that would be really great many thanks!
  • Computers & ... Master
  • 3,795 Answers
If the connector fits the space you don't have to use all three pins but simply use only two of them, though you could use all three if you want by doubling the neutral... In reality it doesn't matter what you do as long as it is non-reversible and the plug and socket are wired to be compatible.
Posted on Mar 24, 2017
    Top Expert:
  • 76,848 Answers
You can find this part on ebay.
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Battery Won't accept charge, after soldering job
If the ground isn't soldered properly that could happen. If you run your computer in your car and you use a power inverter plugged into the cigarette lighter and your battery in, that can cause problems charging the battery as well.
Posted on Jun 27, 2008
SOURCE: How to open case Toshiba Satellite L355-s7905
Hi I have the same laptop and had the same thing happen. I am not a tech, just some dude that is handy and has "messed" with hardware for a bit. So this advise is "USE AT YOUR OWN RISK", I'm not responsible for anything. Well with that said here you go.
Remove the batter for safety. As you go keep the screws separated so you don't have to remember which is which when you put it back.
Flip the laptop over and you will find about a dozen screw holes labeled F7. You need to remove all of these to open the laptop. You'll find some running along the back edge of the laptop as well.
In the battery well, you'll find some more screws labeled F4, you should remove these as well.
There is a slider screw towards the right center of the machine that helps hold the cd bay in place, you don't have to remove this one, but you can in the even that you need to move the bay to gain better access to the DC jack.
Once you remove all the screws, flip the laptop up right. Open the screen as if you were going to use it.
Along the top of the keyboard, you will see that the bezel edge has a break away section the same with as the key board.
Using a small flat head screw driver pry it open from either the left or right side, and continue unclipping it across.
This will expose four very small screws. Remove them making sure to keep them safe, as they are holding your keyboard in place. Once you remove them, slowly seperate the keyboard from the body of the laptop. You will find a flat wire connected to the mother board from the keyboard. You can use a toothpick to slowly slide out the white edge from the brown connection bridge. Once you slide the white plastic peace away from the brown the wire will come out easily. BE CAREFUL with the wire since it is very fragile
Now you should have the keyboard separated from the laptop, put it in a safe flat place and continue.
On the left side hand of the laptop body is a card slot, use it as a finger hold to gently but firmly pry the laptop open. It is held together by clips running along both side edges and the front edge. These can be a little tough to open, so apply slow gentle force till you hear them pop open.
Before you pull it apart after unclipping it, use the same method used to remove the keyboard flat wire from the mother board connection on the three connections holding the top part of the machine to the motherboard. You'll find two towards the bottom center and one at the top left corner. Play close attention to the small flat white one as this is VERY fragile and the copper flanges at the end can bend very easily.
At this point you should be able to freely separate the top half (cover) of the pc from the bottom. Exposing the insides.
You'll be able to easy work with the dc jack now, in my case it was the plastic housing of the body of the laptop that broke. I held it in place with a dab of hot glue.
If you find that the CD drive is in your way, you can remove the two small black screws on either side of its copper connector, then lift the back of the bay up of the body and slow pull it and lift towards the left.
Work backwards to put it back together.
Posted on Mar 22, 2010
  • 109 Answers
SOURCE: I replace the dc power jack on a toshiba satellite
this sound like there is a short in your soldering, did you solder the port directly onto the motherboard. just go over all the joints and make sure there is no shorts
Posted on Mar 28, 2010
SOURCE: I have Acer Laptop with a JV50PU motherboard which has a faulty DC input socket connection. The laptop works OK on Charged battery but not on DC input. Is it possible to get a schematic of the motherb
If the DC Power Jack is soldered onto the motherboard then take the time to unsolder it and remove it. Then buy another DC Power Jack which costs less than $8.00 and solder it into it's place. Normally when it is soldered onto the motherboard there is no cable involved. That's all there is to it if it's soldered onto the motherboard.
If it sits on a slot in the motherboard and has a cable harness attached to it then you can purchase that too for less than $15.00. All you do then is follow where the other end of the cable harness plugs into the motherboard and unplug it. Then place the new dc jack in the slot where the old one sat and plug the other end of the cable harness into the motherboard.
Posted on Mar 20, 2012
My toshiba a 205-s5825 satellite wont power upo and no lights nothing
The problem is in the power supply adapter, or the dc jack in the laptop is loose, if you move the cord from the power adapter to the computer and it comes back on then it is more than likely the dc jack in the laptop that is attached to the motherboard. The remedy is to replace the dc jack or resolder the old one, in order to do this the computer must be taken apart down to the main board for service.
Jul 09, 2012 | Toshiba Satellite A60 Notebook
I have Toshiba Satellite A200-1CC. It wont give a sign of life when the power button is pressed. AC power cord with jack are okay, Wall power cords are new. It won't fill the baterry, but when the bat
first try to check if your toshiba is still part of the warranty. if this is good, much better to go to the service center and they will replace the battery pack of your laptop.
Dec 15, 2011 | Toshiba Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
My tosiba satelite a75-5209 not switch on
It could be a faulty battery. Remove the battery & try to power up the laptop.
If the laptop did not power up after removing the battery, then notice the power receptacle where you plug the power adapter's cord to the laptop. While plugging the power cord in, notice if there is a spark occurring at the power receptacle. If the spark occurs, then disconnect internal drives & connectors one at a time until subsystem with short is identified. If power input still a short with bare motherboard, replace the motherboard. If the spark did not occur, then inspect the boards for burnt or melted components, cold solder on DC jack, open connections, or unseated cards.
Feb 06, 2011 | Toshiba Satellite A75-S209 Notebook
Will not boot up, screen is blank power light comes on for a few second, then turns off
Either your DC jack is bad the motherboard is bad or the power supply is bad. The DC jack on that one is NOT soldered in and fairly easy to replace if you know how to tear it down. Toshiba uses a clip in clip on DC jack instead of soldering them to the board. Start by ohming out the power supply make sure its placing out the correct amperage. Thibk its around 1.58 amp at 19volts. You can see 4 sure looking at the label on it. If its good I would take it to a qualified shop to have the DC jack and board tested to see which is causing your power issue. The average replacement laptop board is $285 not including labor. DC jacks run about $5 but the labor should run around $100
Sep 17, 2010 | Toshiba Satellite A200-0ET00X Notebook
Have a brand new Toshiba satelite and it won't open. The Num lock key is lit .
Take the battery out and wait for three minutes. Put the battery back in. If this doesn't work, try starting it without the battery.
If it is brand new, I would take advantage of the warranty on the laptop. This sounds like a faulty battery.
Sep 16, 2010 | Toshiba Satellite A135-S2386 Notebook
Toshiba plug-in ac adapter LCDlight flashing and wont boot up
It may be that you need a new, (Or good condition used), motherboard. You may not.
The problem could be the DC Power Jack. The DC Power Jack is small, and the body is made of plastic. Sometimes there is a metal shell around the plastic body. (The jack is a rectangular shape, and is just a little larger, than the outside portion of that AC adapter plug!)
This is an example of a DC Power jack for a Toshiba Satellite a215-s5807,
http://www.notebookworks.net/ProductDetails.asp?ProductCode=NBW52-0133
As you know there is a metal pin in the center, and at the back of the round hole, there are flat metal contacts.
Let me explain the construction of a DC Power Jack, and how it's mounted to a motherboard. This all has relevance to the solution.
Your laptop uses DC electricity. (The AC adapter converts AC to DC. Your laptop battery, and a flashlight battery, are examples of stored DC electricity)
DC uses a Positive connection, and a Negative connection. The metal pin in the center is Positive. The flat metal strips at the back are Negative.
That laptop DC Power Jack has metal prongs, that come out of the plastic body. One prong, (Or pin), connects to the Positive metal round pin, in the center of the jack.
There may be one, or two prongs, (Or pins), that come out of the plastic body, and connect to the Negative side of the jack. (Flat metal strips)
These prongs go down through holes in the motherboard, and are soldered on.
With the AC adapter plugged in, an accidental bump on the plug itself, could break the body of the jack, or break solder joints that hold the jack to the motherboard.
AC adapter removed, and battery removed. Use a NON-metallic object, and see if you can make the center pin of the jack move. See if the entire jack itself seems to move.
A.If the center pin moves, you have a broken DC Power Jack.
B.If the entire jack moves, you have cracked solder joints. (Broken)
Replacement of the DC Power Jack for A.
Re-solder the solder joint/s for B.
Cost of replacing a jack at a reputable computer repair shop? $90 to $150
Cost of re-soldering solder joints? $50 to $90
Cost of replacing the motherboard?
$250 on up.
If you are a skilled person with the correct tools, it is feasible for you to replace the jack, or re-solder the solder joints.
It is also feasible that you yourself, could replace the motherboard.
Some laptops have a poor motherboard design, for where the DC Power Jack is mounted to the motherboard.
Crude explanation would be, that the main body of the motherboard is a 1 foot square. Then a 2 inch square comes out of the side of the main body.
The DC Power Jack is mounted to that 2 inch square. From accidental bumping, OR just normal usage of inserting, and removing the AC adapter plug, this 2 inch square can crack away from the main body.
This, of course would require a motherboard replacement.
Disassembly instructions for a Satellite A200 and A205 Series laptops. Very close to the A215 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
(Don't forget to buy, and use a cheap ESD wrist strap, to prevent static shock to the delicate hardware components, inside your laptop. Average cost is $7)
Aug 04, 2009 | Computers & Internet
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
DC jack broken
My computer repair company aka my username does this repair all the time. Here what you should get.
1. 30-watt iron
2. Light rosin solder ( i think Im using .028)
3. solder ******
4. desoldering braid
Here are some toshiba manuals
When taking apart the laptop I pretend a piece of paper is the laptop and I'll draw holes on the paper to represent the screw holes on the actual laptop and when I unscrew a screw I will take in onto my mock up paper. So I will have a paper for all the bottom screws, a paper for the top cover screws, paper for the motherboard screws etc.
When you finally get the motherboard out of the case, desolder the old jack(from the underside) use the solder **** first and then the braid. Once all 5(usually) pins are desoldered wiggle the old jack out. Then put the new jack in and solder it to the board (on the underside)
May 16, 2008 | Toshiba Satellite 1135-S155 Notebook
Toshiba Satellite 1415-S173
Hi
DC jack replacement is easy however requires a bit care since its mounted on the mainboard. Desolder the old DC jack. Solder the new one firmly. Dont keep the soldering iron too long on the PCB as it will damage the lines and will deform the DC Jack. You can get DC jack very low cos from local repair stores or you can order from Toshiba parts depot (800-524-8338)
Please post your question if you need further assistance.
Good Luck
Feb 09, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
