Question about Zebra LP 2844 Thermal Printer
Zebra 2348+ prints labels really slow - Zebra LP 2844 Thermal Printer
5 Suggested Answers
  • 15 Answers
SOURCE: Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
Posted on May 30, 2008
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
  • 62 Answers
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Posted on Apr 18, 2009
  • 31 Answers
SOURCE: Zebra 2746e will skip leaving a blank label while printing.
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
I have a Zebra 2348 Plus that will print out the label I need but then spit out 5 or 6 blank labels. How can I correct the issue?
Have you tried the AutoSense, Media Calibration? the printer self adjusts for the labels you are using. The procedure starts on page 11 of the manual. Incase you have misplaced your manual you can download one here....
https://ups.zebra.com/UPSZebraWeb/support/downloads/2348P/pdf/2348P-user-manual.pdf
Good luck
Sep 26, 2016 | Zebra Office Equipment & Supplies
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
How do I stop my printer from skipping a blank row of labels in between each row I print?
I was using LibreOffice Writer to print terminal block labels on my TDP43MY and was having all kinds of problems. (I tried EasyMark too, but had just as many problems.) The printer was constantly switching landscape and portrait modes on me. It would print 2 sets of good labels (portrait) and then the next label would be landscape. It did this no matter if I printed one page at a time or if I printed the whole document. I spent over half a day trying to get it to work, and finally succeeded - read on.
No surprise that the Panduit TDP43MY printer is really a Zebra printer. I discovered this by accident when I first got the printer. I connected it without first installing the driver and windows asked for a driver for a Zebra printer. Knowing it was a Panduit, I rejected windows offer and installed the Panduit driver. I spent a whole day trying to get it to print correctly and decided I would try windows recommendation of a Zebra driver. I did some digging and discovered it is a Zebra TLP 3842 printer. I removed the Panduit driver and installed the Zebra TLP 3842 driver. The version I have says "Windows driver for ZDesigner TLP 3842 Version 5.1.07.6290 Copyright 2016". I then used LibreOffice Writer to print my labels again. Wonder of wonders it printed with ZERO problems! Yeah for Zebra!
May 06, 2014 | Panduit TDP43MY Thermal Label Printer
2348 manuals
try to reset printer to factory default. dowload the seagullscientific drivers and reset from there, much easier. hope it helps, Paulo.
Mar 27, 2014 | Zebra Office Equipment & Supplies
We use the zebra printer for jewelry labels... it will print one label then spool out the roll with out stopping... i can remove a label ahead of the one im printing and it will usually stop there...i...
I would say try another manufacturer !
Are you sure that your driver is correctly installed and you label size correct?
This looks like you have a longer label than you real ones.
Jul 24, 2011 | Zebra LP 2844 Thermal Printer
My zebra 105se printer got move to a different location and now it is printing very slow. Is there a way to set the speed faster?
Our company is an authorized reseller for Zebra printers, as well as labels & ribbon. You can adjust the speed and heat settings on your zebra printer, however your labels software will often override any settings. What software are you currently you using? If you can let me know, i will tell you how to change settings in your software- which will override the print to print faster.
Conti Systems
Bethany Miller
972 870 9400x105
www.contisystems.com
bethany@contisystems.com
Feb 15, 2011 | Zebra 105Se Thermal Printer
Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
Aug 13, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Delay between labels
download the manual from zebras website im sure its not that complex to adjust it. www.zebra.com
Aug 16, 2017 | Zebra Z4Mplus Label Printer
Slow Printing on Zebra Z4M
An unorthodox solution is to install an old driver. Another solution is to use with Codesoft the driver from www.seagullscientific.com, and with Zebra Designer, the Zebra Designer driver. If the printer is connected to the serial port, speeds up communication.
Roberto Martinez
Mar 30, 2009 | Zebra Z4M Printer
Zebra LP 2844 Thermal Printer Logo
78 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
