Question about HP Compaq nx6110 PC Laptop
BCM92035NMD cable pinout - HP Compaq nx6110 PC Laptop
Want to connect 40 pin LCD ribbon cable to the 15 pin D type VGA
VGA pinout?
Not a prob,
http://pinouts.ru/Video/VGA15_pinout.shtml
Pinout of that 40 wire LCD ribbon cable in your hand?
Dunno
Each manufacturer is different.
IF, you find the pinout of JUST THAT LCD cable you have, LET ME KNOW.
Post back in a Comment, or click on Reply at the end of this solution.
Regards,
joecoolvette
May 12, 2013 | Computers & Internet
Connecting usb
Usually red white green and black unless the motherboard has a cable connect lead already
The USB Pinout:
Pin
Name
Cable color
Description
VCC
Red
+5 VDC
D-
White
Data -
D+
Green
Data +
GND
Black
Ground
http://pinouts.ru/SerialPortsCables/usb_cable_pinout.shtml
http://pinouts.ru/Slots/USB_pinout.shtml
http://pinouts.ru/connector/4_pin_USB_A__USB_B__mini-USB_jack_connector.shtml
hope some of these will help you
Feb 24, 2012 | Foxconn 6100K8MA-RS Motherboard
I've got an Comp with a msi n1996 motherboard. but the cables are hanging lose. now I'm searching for a lay-out how / where to connect the cables (power sw, hdd led, etc)
There should be some white writing on the motherboard at the bottom right labeling where the cables plug in. The motherboard manufacturer should also have a manual showing the pinouts on the motherboard.
if that does not help try
http://www.fixya.com/uploads/images/273B68A.JPG
or
http://image.pinout.net/pinout_4_pin_files/intel-front-panel-pinout.gif
Apr 06, 2011 | Computers & Internet
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
This card it's breakdown :fcc id:qds-brcm1009 (burn)
Hi There,
This is a Broadcom Bluetooth module (BCM92035NMD).
You should be able to find a replacement quite easily.
Just search for the part number above on Google;
http://www.google.co.uk/search?q=BCM92035NMD
Regards,
MC.
Sep 03, 2009 | HP Compaq nx6110 PC Laptop
Cable end chopped off need to know pinout mapping to reattach a new cable end to attach to computer.
All VGA connectors use the same pinout. Here's a link that shows you the VGA Pinout,
http://www.interfacebus.com/Design_VGA_PinOuts.html
More monitor pinouts,
http://www.montest.com/technote.html
Apr 21, 2009 | KDS K717s 17" LCD Monitor
Need pinout for octopus cable
Try http://www.bobdbob.com/~protius/pinouts/
Jun 04, 2007 | Addonics FlexPort 42 (AEFLEX42) Parallel /...
HP Compaq nx6110 PC Laptop Logo
336 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
