Our remote died to our Vizio ....checked batteries, etc...have been having problems for a while...bought a new universal Vizio remote...keyed in all the numbers....last four work...but still is not working..took it back to Walmart..he got it working in some Tv's down there...keyed in the 1000 and said it would work in our Tv...still doesn;t...manually adjusting the channels and volume, etc is difficult...is it our TV or what? The Tv is about 3 - 4 years old and works fine otherwise
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 103 Answers
New TVs and older ones, even recent model changes usually have different codes. Read the new remote closely. there is a section about finding the code manually. It is a pain, but works.
Posted on May 30, 2017
  • 21 Answers
SOURCE: remote control not working
if you still have a problem (and the tv!) email me at gmail.com
Posted on Aug 31, 2007
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
  • 29 Answers
SOURCE: Vizio 32 inch -- using remote to change channels.
tyr to dismatle youre remote and you can see the key pad
,clean it by using pencil eraser.coz there are full of carbon inside.
Posted on Jan 20, 2010
caroldon
  • 17129 Answers
SOURCE: channel up/down button on remote for 37" vizio tv
It is possible that the pads are worn out or there is damage on the main board, possible carbon track failure . you might need to reform the tracks or use a remote control repair kit to retrack. Also in some cases the controller IC can be defective as it fails to detect the selected port.
Please try this link for some tips:
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Oct 04, 2011
My Visio E371vl won't power on with remote. I changed batteries & even bought a universal remote & no power on. the new remote works on other Visio TVs. I can turn the tv on with manual controls.
Dear Anonymous,
  • Unplug the TV for 20 Minutes and plug it back.
  • If that does not work, the remote Sensor on your TV is defective.
  • Take it to a repair shop.
Here is a link to Vizio Support:
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jul 11, 2015 | Universal Televison & Video
My dog recently destroyed my vizio remote, con change the input without the remote or must I buy a new vizio remote?
Sorry about the 2 add ons I have no idea but I had to get a universal since mt on off button quit
Jan 21, 2015 | Vizio Original Smart TV Remote...
My Vizio Bluetooth remote with keyboard has stopped working. I have spoken with Vizio tech supp. to no avail. I have a remote I used with my old TV issued by Charter because I have Charter cable. I want...
you need to contact charter for support on their remote and how to reprogram it for your new tv. for most universal remotes there is setup key or you have use a key combo to press to enter into setup mode and a user's for the cable box may have this info. however, if you do not have or did not get a user's guide then you need to contact your charter cable company for the info needed to get the 2 devices working together. refer to cable co. tech support.
Aug 25, 2011 | Televison & Video
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
My kids broke the remote that came with my vizio soundbar, I bought a universal that worked fine for about 6 months and now I can not get a remote to work with my vizio at all. I bought a new remote and...
The remotes you have purchased and tried, are universal remotes ? For an item like that the default remote that came with it would work best. I would email Vizio customer support and get a replacement. I had to do the same thing about a year ago. They charged me 10 dollars for a new one.
Post back if you have any question's or comments.
Thank you for choosing Fixya!
-Daniel
Mar 21, 2011 | Televison & Video
I've gone through 3 remotes on my Vizio XVT553SV 55 in. LCD TV. The first one that came with the TV in the box quit working so I called and ordered a replacement. During the meantime, I went and bought a...
Ur universal remote have codes problems,low in batteries or replacement batteries have problems with codes.Re enter the codes again,for ur tv model.
Dec 09, 2010 | Vizio XVT553SV 55 in. LCD TV
My universal remote and vizio remote no longer operate the tv. how do i fix it.
I have the same problem. I just called Vizio and they advised me to take the batteries out and press each button two times, replace the batteries, and try again. When that didn't work, they said they were going to send me a new remote. I told them the universal didn't work either and they said they have to send the factory remote first, if that doesn't work they then have to send out someone to service it. Their support is 1-877-698-4946. Have serial number ready.
Jun 24, 2010 | Vizio Gallevia GV42LF 42 in. LCD...
Try this;
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 32L, remote sensor malfunction
UNBELIEVABLE!!! mattymcmatt has the solution!!! I have had trouble with my Visio 26" remote ever since I got it several years back. Had to mess with the batteries, BUT Finally it quit entirely several months ago. I have tried everything... batteries, unplug TV, press each button on remote, etc... just bought a new remote, and tried all the above 'fixes' AGAIN nothing has worked. read mattymcmatt's fix of unplugging tv held down the on button on the tv for little over a minute, plugged tv back in and and VIOLA my remote is now WORKING!!! thankyou matty!!!!
Nov 27, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
