Question about HP Office Equipment & Supplies
I am trying to print pictures from my files and I looks like it is going to print but then the fax screen comes up and wants a number to fax to. Help. Thanks.
  • HP Master
  • 4,338 Answers
Go to Start > control panel > Printers. In the printer queue, right click on your printer's icon. On the drop down menu, click on "make default" close the queue and then try to print.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 25, 2008
HP 9800 does not print picture
actually it happens with some pictures and Graphs in word file
best way to make pdfs or u can try with print screen that picture and again put in word file then it will comes on paper
May 04, 2012 | HP DeskJet 9800 InkJet Printer
Hello, I have Canon Photo Paper Plus Glossy, and i want to use this to print off some passport-like photos through Brother printer. How do i do this?
If you have windows XP or later you can use thw Windows picture/fax viewer. Unfortunately I cannot insert PDF files I have created here. In picture/fax viewer you choose contact prints or wallet prints and select number of times each picture is used.
Aug 09, 2011 | Computers & Internet
My 575 fax won't send; it keeps printing "poor line condition". Is there something I can do? I am just trying to send a fax like I always do. It makes the noise at first like it does when it transmits,...
If this is happening to only one number you're trying to fax to, then the problem is most likely on their end, not yours. If it is happening with all the numbers you fax to, then I would suggest checking the telephone line hooked to the fax. Look for loose connections, or perhaps a bad cord from the phone outlet. The connection could be good enough to get a dial tone, but not secure enough for the fax to operate. If none of that holds true, I would suggest taking it to the shop and let a technician look it over.
Oct 23, 2010 | Brother FAX-575 Plain Paper Thermal
Can I print a list of faxes sent the past week on my HP 7680?
Sorry but NO.
You SHOULD be able to print off a list of the NUMBERS you dialled but not the actual fax which is actually sent as a PICTURE. This is gone forever.
For the numbers go into the memory of the machine and look for the list in SENT.
Feb 26, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
HP Photosmart C7180 won't print!! I had an IT person come to my home earlier today, and it was printing when she left. Not 20 minutes after she left, it wouldn't print for me!!! This is the second time...
It would seem that your default 'printer' is set to fax and not print.
When you select print from the file menu it probably says something like HP Photosmart C7180 Fax in the printer option. If it does, go into the printer section from the control panel and make the C7180 (without the fax reference) the default (right click>set as default)
Oct 15, 2009 | HP Photosmart C7180 All-In-One InkJet...
I can't send a fax from my vista program with out printing out the fax first and sending it the old way, and that waste paper. in the xp or word 2003 I can go to the send in the file and the fax wizzard...
You need to go to printers and choose 'add a printer'. Under add printer, choose the printer called "MS FAX." That will install microsoft fax as a printer. Next, print your document by going to File, Print... (make sure it says "PRINT..." then you should see a selection screen, choose ms fax, and there you go. That should do it.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
HP C7280 All in one wont send faxes
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Feb 02, 2009 | Office Equipment & Supplies
How do I fax?
Sending a fax from your computer requires a fax modem and that your operating system be configured to allow you to send and receive faxes.
to send from fax software
step 1 Prepare the document that you want to fax. Step2 Prepare a fax cover sheet, if desired. Step3 Open your fax software - such as Microsoft Fax or Microsoft Exchange. Step4 Look for an icon or menu command that allows you to send a fax - such as Send New and Send Fax. Click on that item. Step5 Follow instructions for entering the fax number of the recipient and any other requested information. Be sure to include area codes and long-distance information if needed. Step6 Indicate whether you wish to send a cover sheet. Step7 When asked to attach the file, follow instructions to attach the file that you want to fax. Step8 When ready, click Send. The fax will begin to compile the information and, when ready, will dial the remote fax machine. Step9 When the connection is made, the fax will be sent. To Fax From Your Word Processing Program Step1 Some software products, such as Microsoft Word, allow you to fax a document without opening your fax software. Step2 Open the document that you want to fax. Step3 From the File menu, select Print. The Print window opens. Step4 Instead of printing to your default printer, look for an option that allows you to Print to Fax. Select this option and click Print. Step5 You will be asked to provide the recipient's fax number and other assorted information as with a fax program. Step6 The fax message compiles, the modem dials. If the connection is made with the other modem, the fax will be sent.
Aug 26, 2008 | Computers & Internet
Hi, I have a HP Photosmart C6180 and am trying to send a fax. Have tried fax test - everything seems OK. But when trying to send a fax direct from desktop from Word - it just sits in the print queue...
I not sure I get it???
are you printing or faxing???
if faxing from word ibeleive you need to choose fax then a screen comes up to type in info of phone number, name , etc....
if printing click on print choose the model and it should print.
Aug 11, 2008 | HP Office Equipment & Supplies
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
16 people viewed this question
Ben Johnson
