Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover f7410900 my hoover F7410900 carpet cleaner is not dispensing solution only water
    Problem Solver:
  • 6 Answers
You far got to risens it out when you used it so now you have to takeit apart the heater is pluged up
Posted on Oct 25, 2008
No water getting to brushs
Hi! Sometimes it is necessary to prime the trigger under the handle to get the solution flowing. To prime the trigger, recline the handle and pump trigger about 60 times. Then, power the cleaner on and squeeze the trigger for about 60 seconds. The solution should start to dispense. If it is still not dispensing there may be an issue with the pump assembly on the cleaner. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate one nearest you. Service Center Locator
Hope this helps!
Jun 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
May 17, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
Mar 16, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Instruction manual for hoover swish carpet cleaner
my hoover swish dosent seem to **** up much of the water out of the carpet carpet is still quite wet and bot much water is sucked up for the amount of water that goes in the water dispenser
Nov 26, 2010 | Vacuums
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Apr 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover cleaner model f5865-900
There is no belt, either the turbine part #43191003, or the brush block, the shaft that goes up into the turbine broke off part #48437022. The turbine is what drives the brushes.
Feb 02, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
213 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
