Question about RCA Lyra RD2780 Digital Media Player
Recording Each time I try to record a VHS tape I get this error; "Warning" No Video Signal Present Cannot Record I have read the manual and have it hooked up correctly. So what can I do to get it to work? Thanks, Keith
You have to play the vhs before hitting the record button or the lyra will pick up no signal i had the same problem recording my dvds
Posted on Jan 26, 2008
HOW DO I RECORD WITH A SONY SLV-N77 MANUAL DOES NOT HAVE ANY DIRECTIONS
Looks like a great brand with good features for the price.
  1. Connect Video & Audio Cables to a video signal source
  2. Connect Power Cable
  3. Turn on VCR.
  4. Insert a blank tape in the VCR.
  5. Note - A Broken Tab on the back of tape will prevent recording. This is called Write Protection.
  6. Cover the tab hole if you want to record over old video.
  7. Press RECORD on the VCR remote control.
  8. After a minute, press Stop, then PLAY to see recording.
  9. Cheers
Aug 18, 2014 | Sony SLV-N750 VHS/S-VHS playback VCR
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
I am trying to copy a VHS to DVD from a VHS player. I have a Sony VRD-MC6 multi-function DVD Recorder. I am using the A/V cable and have verified that they are correctly placed. The Sony player will...
Is it possible the VHS you're trying to copy is copy-protected? Apparently, the MC6 displays "waiting for signal" when you're attempting to copy a copy-protected (commercial) video. I had success converting my own homemade VHS tapes. I just bought my MC6, and thought I'd pass along some tips I got from others: You know you're recording when a red ring around the large Record button lights up and it actually says "recording" on screen, and adjust HQ to SP to get 2-plus hours of video on the DVD.
Jan 24, 2011 | Sony VRDMC10 DVD Recorder
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
When recording from vhs tape, and the signal is poor at times, the machine automaticaly stops recording temporarily and resumes when the signal is more stable. how can this feature be disabled?
If you are recording VHS tapes that contain macrovision, and most commercial tapes do, you can't record them with this DVR because it is compliant with the law that says you can't do it. So don't try. Download nearly every movie/tv show from the internet instead.
If you are recording from VHS tapes that you have created yourself from TV sources, or from camera, you must stabilize the picture. There are several devices like that. Do a google search on "vhs stabilizer".
Apr 21, 2009 | Protron PD-DVR100 DVD Recorder
Cannot record from cable box dvr to vhs tape
DVRs have embedded digital rights functionality to prevent you from doing what you are try to do. In addition the VCR has logic to respond to that and prevent recording by blocking the signal.
That is likely why you cannot get a signal.
Feb 24, 2018 | Panasonic DMR-ES35VS
Recording from the Mini DV to VHS Tape
Mini dv is a digital recording and VHS is analogue so they are incompatible. Does your camera have an analogue output? That is a lead that ends with something like RCA plugs or a Scart plug. Then you can feed the signal into a VHS recorder.
Aug 23, 2008 | Canon ZR45MC Mini DV Digital Camcorder
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Panasonic DMR-E55 Won't Let me Record my own VHS
Hi
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
Have fun....
Jan 21, 2008 | Panasonic DMR-E55 DVD Recorder
VHS Recording Tape
not much of a help but sounds like your record head is bad on the vhs heads,
use cleaning tape try that, if that fixes great, if it helps but not fully there, you might have to clean them by hand with very soft paper town and rubbing alcohol rub side to side very easy , if none of the above work you have a bad record head or record board, not worth repair vs cost
good luck
Aug 25, 2007 | Philips Magnavox 20MC4304 20 in....
RCA Lyra RD2780 Digital Media Player Logo
62 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
