Question about Tomtom GPS
Tomtom go730t, switch on and get start up screen then displays "no maps found".
    President:
  • 2,712 Answers
Make sure that you have the map installed first of all, or you have the SD card inserted correctly (if using one).
If that is OK, try resetting the device. To reset your TomTom device, do the following:
  1. Charge your TomTom
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. The reset button is located on the underside of the device.
  4. Turn your device on
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Should that still not help, try to download and install the map from TomTom website. Instructions HERE
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 25, 2008
Trying to set up TomTom 340 XL TM. downloaded new map, etc but when i want operate it, i get a 'no maps found!' message. At my TomTom Home screen, it doesn't appear that maps are not on my device but the...
It happens when the device doesn't recognize the maps. That's why - in such a case - you have to downgrade the version of the maps.
What Navcore Version do you have on your device? Here's a cart to help you.
[DON'T FORGET TO RATE MY SOLUTION IF HELPFUL! THANK YOU!]
Mar 06, 2011 | Tomtom GPS
Screen reads"no maps found"
I found this article online, and it may work for you:
"Ok this has worked on at least four tomtom one’s
And one xl’s that i have tried,
First of all connect your tomtom to your computer.
making sure your online,Go to log on.
if you’ve not created an account create one now.
If you’ve had to create an account restart tomtom home.
You should have the tomtom home screen in front of you,
Now even if tomtom home is showing you logged in, ignore
this click your email adderss in the top right hand side of the screen
and log in again and click continue.
Then click Device/disconnect device.
Now your tomtom will update itself and your maps will be restored"
Jan 11, 2008 | Tomtom One Europe v2 GPS Receiver
I PURCHASED A 335TM XL TOMTOM GPS AND AFTER FOLLOWING INSTRUCTIONS ON THE VOUCHER, MY TOMTOM SCREEN, DISPLAYS " NO MAPS FOUND.
You have to first load maps on the gps before you can use it. You go to tom tom website, then you update your tom tom with maps, then register your device. After doing that, I assure you will be able to use the gps.
Dec 26, 2010 | GPS
My tomtom gps display "No maps found" I already
Hi try the following advise in my previous post on how to recover missing components including missing map:
http://www.fixya.com/support/t3710244-think_deleted_actual_program_tom_tom
Hope you resolve your issue as you have several post on this issue.
Let me know how you go!
Sep 27, 2010 | Tomtom ONE 3rd Edition GPS
Xl 330s will not locate/display maps, just a blank screen saying "no maps found"
suspect that your maps file is corruped or lost. this may have occured due to a drop or other inteference such as high magnetic field or eletromagnetic interference.
if you connect your tomtom to your pc you can view inside to see if the maps are in the device. if they are not then you may have to redownload them from any map software you had or from the TOMTOM website using tomtom home.
Jan 01, 2010 | Tomtom XL 330S GPS Receiver
Tomtom one displays no maps found
The problem with that approach is that you cannot transfer maps from another device onto yours without product key activation codes. This is to prevent piracy or abuse of maps on individual devices.
Did you find a good solution?
May 22, 2008 | Tomtom ONE GPS Receiver
No maps found??
my tom tom 510 would start, i have charge the tomtom with green light on, but tomtom is not coming up
Feb 09, 2008 | Tomtom GO 510 GPS Receiver
No Maps Found
Everyone with software issues needs to use the tomtom website & enter your problem there someone will be able to talk you through wipeing it & starting over.
http://www.tomtom.com/support/support.php?ID=2
Dec 10, 2007 | Tomtom ONE GPS Receiver
GPS Logo
121 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
