This problem should be removed because:
Problem with Vacuums
the ball on my dyson vacuum does not turn anymore
the actual ball does not turn & I had a little plastic piece with a metal wire connected to it come off the right had side would that be it & if so where can I get a new piece?
Solutions (1)
Hi Linda,
I'm sorry to hear you're having difficulties with your Dyson. If you're concerned that a piece seems to have come off your machine, it's probably best if you get in touch with us directly so we can provide further assistance. If a repair is necessary, this should be covered by our 5-year guarantee - all you need is a copy of your proof of purchase.
Please give us a call free on 0800 298 0298 (UK), or 1-866-693-9766 (US) - it will help if you have your machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Suggested Solution (3)
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
The Dyson site has a help section where you can read how to take the unit apart to unblock it. Maybe your solution can be found there.
Hard to tell since you didn't say what the part is.
Source: Dyson dc15 ball/ taking apart
At the bottomor end of the wand there is a curve hose. That is removable. Pull the wand out all the way and turn that curved piece down. It slides out. There is a little channel. It should come right off. I've been there. Let me know if it helps.
Jacquie
Source: Dyson Ball Vacuum
beater bar on Dyson upright won't turn when...
When handled is lowered fo vacuuming beater bar will not turn and suction doesn't seem right. When vacuum is running in upright position...
motorized brush bar not turning on Dyson Vacuum
Started as an intermitted motor issue not turning the brush bar on the bottom of the dyson ball when I pushed it forward and as I returned...
It will not turn on. No lights, no power what so
It will not turn on. No lights, no power what so ever. It is not even one year old yet.
I have a hoover light & soft upright sweeper.
I have a hoover light & soft upright sweeper. In replacing the belt a "v"metal clip popped out. It is metal in a shape a...
I got a little bouncy ball stuck in the handle of
I got a little bouncy ball stuck in the handle of my Simplicity Jessie Series. It is stuck in the bend in the handle. I can see it very...
Add Your Solution
Vacuum cleaner has no suction
My vacuum has no suction. How can I get a manual to troubleshoot it.
NO SUCTION
nO SUCTION
I need to replace the motor
makeing noise when I turn it on, tokk it to get fixed and was told that the motor needs to be replaced.
Top Vacuum Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
