Question about Gateway MD7818u Notebook
NEW Battery not properly charging
I have a gateway MD7818u, replaced my battery with third party battery bought on ebay. My AC adapter is fine, and I can plug in the ac adapter and start the computer just fine without the battery. When I put the new battery in, plug in the ac adapter without turning on the computer my computer charging light flashes orange for a few minutes, and slowly turns to red and stays on solid. I turned on my computer booted windows, and battery meter shows plugged in and not charging (with 0% available). The led charge light on my computer still stays red, while on windows. I unplugged the AC adapter while computer was on, and the battery lasted 1.5 hours before it immediately shut off. So the battery is holding a charge, but not appearing to be charging or holding a charge on the computer. Also if I leave it plugged in, it seems to be giving the battery some type of charge because I can keep using it on battery power if i leave it plugged in to charge a little bit, regardless of my computer and LED indicator telling me it's not charged. However, I can't power on the laptop with just the battery, I do have to plug in the AC adapter, but then I can remove it immediately after and it runs for the 1.5 hours on high load. I don't want to ruin my new battery without knowing how to fully charge it, and discharge it, to make it reach full capacity so How can I fix this?
  • 734 Answers
Batteries have electronics data that software has to get to properly charge it. Newer lithium batteries maybe different. But apparently, you have a work around for a lengthy use of the new battery.
Posted on Feb 17, 2012
AC power adapter wattage cannot be determined
The AC adapter needs to be replaced. You can buy one from Dell for about 100-200 dollars. If your laptop is still under warranty, the charger is often covered under the same warranty as the laptop and should be replaced under warranty if applicable. You may also buy a third-party charger off of ebay or amazon much cheaper, but this is not recommended. If you do consider a third party charger, make sure that it has the same wattage, voltage, everything! Good luck!
Mar 23, 2013 | Dell LATITUDE Computers & Internet
My laptop wont turn on without a charger
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue. Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop. Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
Hope this helps.
Jan 21, 2013 | Dell Inspiron Computers & Internet
Hp 2510p not charging
Third-party utility
hope this helps
Try removing the battery from the back and then running it directly through the AC adapter. Sometimes the battery and AC adapter have conflicts and it can cause a laptop to become inoperable.
If this doesn't fix the problem in any way, I would recommend trying a new battery or AC adapter.
hope this helps
Oct 09, 2012 | HP Compaq 2510p Notebook PC
Msi wind u160 runs on mains power only
Third-party utility
hope this helps
hope this helps
Oct 08, 2012 | MSI Wind U160-412US Black Intel Atom...
LG laptop battery
Third-party utility
hope this helps
Sep 06, 2012 | LG LB32111B, LB52113B, LB52113D,...
I have charged it and i still cant get it to turn on.
Third-party utility
hope this helps
Sep 05, 2012 | Computers & Internet
Computer will not start up
Third-party utility
hope this helps
Aug 30, 2012 | Dell Inspiron 1501 Laptop
No battery is detected
Third-party utility
hope this helps
Aug 24, 2012 | Computers & Internet
What is the solution the battery is fine
Third-party utility
hope this helps
Aug 05, 2012 | Dell Latitude D510 Notebook
Battery is not charging
Hi, You maybe encountering errors such as plug in not charging or no battery detected. If so, there's a posibility that the problem is with the battery itself or the charger that you are using or worse, the DC port on the laptop. Here some steps for you to be able isolate the exact problem and which part is need to be replaced.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard or the Base Cover of the laptop itself.
Hope this will help...Thank you for using Fixya...
Feb 18, 2011 | Gateway MD7818u Notebook
Gateway MD7818u Notebook Logo
800 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
