Question about Sony STR-DB790 Receiver
How can i connect my laptop to a db790 amplifier?
When trying to connect using a phono lead getting very crackly sound/ or n sound at all help please
  • 356 Answers
All you need is a 3.5mm Stereo Mini jack to two RCA jacks. Connect this to the line or speaker out of the laptop into anything but the phono input on your sony. The phono input will be over driven and sound bad and possibly damage something in the system. Try using any other unused device input on the receiver.
Posted on Feb 16, 2012
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Hi, having a problem with
RCA cable. It's called RCA when carrying Line Level audio; Coaxial when carrying digital data.
Does the sub work when you run speaker setup? It's in the manual.
Posted on Apr 01, 2011
dunnbiker
  • 8546 Answers
SOURCE: cant get sound through my
Assign the optical input IAW the manual.
Posted on Aug 18, 2011
C370 faint crackling sound left channel
have you tried looking at your phono leads,turn volume down until it is low enough that you can still hear the music playing,give the phono leads a turn to see if its a loose connection.if not,try the right channel phono in the left channel to see if this fixes your problem.also you could do the same with your speaker leads and see if that solves the issue.maybe a bad connection is the cause?.it may also help to try and move your cd player away from your amplifier.it could also have been overdriven (played too loud for too long) on the night of the party,only you will know if this was the case or not.
Jan 07, 2013 | NAD C370 2-Channel Amplifier
Hi, having a problem with my Sony STR - DB790 amplifier. All my surround sound speakers work fine, but my subwoofer is not. The subwoofer has power and is connected using the co axial cable. The...
Apr 01, 2011 | Sony STR-DB790 Receiver
How do i connect multiple ampliers to one source and equalizer?
why do u want to use 3 amplifiers connected in series ?or even parellel.?remember in series amplifiers 1+1+1 does not make 3.it may make 10,hence the speakers may go bust .
Aug 24, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Denon 2802 amp
Dear Armani,
You cannot put de leads from an MP3 player or your TV into the pre-amplified connection of your Denon,
the phono "stage" is a low input stage, your input from MP3, TV, CD, DVD oscasetteplayer is high output (a 5 to 10 times stronger signal)
Try every other stage like tape 1 or 2, this will work just fine,
succes
Apr 30, 2009 | Denon AVR-2802
Connect subwoofer etc to nad 3020I stereo amplifier
Hi Info
You can use a 2 x male RCA to RCA female adaptor lead(what you need to ask for)  like this one 4d0dcde.jpg
use it to jumper your pre-out/main in connection on the rear, and connect an RCA lead to the Female socket on the adaptor lead. That will get you going. You can get them most places that sell electronic bits and peices. I am happy to answer any questionsa you may have
regards robotek
Mar 05, 2009 | NAD C320 2-Channel Amplifier
Connecting my HP Pavillion DV9500 laptop to my Samsung PS-42Q96HD
Sound more like your problem is with the connection to the TV. Make sure the connection at the TV is to an 'input' connector and not 'output'. Also, from the TV menu, if you can select the output the laptop is using make sure the sound is stereo an not 5.1 or 7.1 or something to that effect. All other connections seem to be in good shape. Good luck.
Feb 03, 2009 | Humminbird Computers & Internet
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
No sound from turntable bought for our hi fi system
Most if not all turntables would need to be connected to a PHONO INput which is high impedance with a high gain pre-amplifier stage. It will not work when connected to an AUX, CD or any line level inputs. Alternately, if your amp does not have any Phono Inputs, you can feed the turntable output to a preamp which can then be connected to any any line level inputs. An example may be found here or here. Additionally, there are some turntables with a built-in preamp.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 16, 2008 | Audio Players & Recorders
Low Audio
You need to connect the turntable to a PHONO input on your amplifier. Not all amplifiers have a phono input, if yours doesn't you need to get an RIAA pre-amp to plug your deck into & this connects to your amplifier.
This is because although the audio outputs on the turntable look the same as all the other components, they are very different. The signal has not been amplified up to line-level like tuners, CD players, tape decks, etc. You need to get this thin, weak signal boosted.
Your 3 options are:
* Connect directly to the PHONO input on your amplifier if you have one. If you don't:
* Connect deck to a RIAA amp (also called a phono stage) then connect to any input EXCEPT phono on your amplifier
*Connect the deck to a DJ mixer then hook the mixer up to any input on the amp EXCEPT phono.
Dec 23, 2007 | Technics SL-1200M3D Turntable
Sony STR-DB790 Receiver Logo
128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
