Question about Farmall Tractor Av-1,super C,100,130,200 Radiator
Farmall super c jumps out of 4th gear
When going thru gears tractor jumps out of 4th gear
SOURCE: it is a 1947 farmall
Two possibilities come to mind:
- the water pump impeller may have so much oxidation on it, it's not pumping enough coolant
- the cooling circuit in the block has so much oxidation in it that it is restricting the coolant flow rate through the block
It's like my arteries, I'm the same age as your tractor, and believe it or not my father once owned that same tractor.
I don't remember, does it have a thermostat? . If it does, you could remove it -- that might help.
Posted on May 07, 2009
wilsodfarm
  • 986 Answers
SOURCE: working on farmall super a tractor distributer had
Remove valve cover,bring #1 cylinder top dead center,make sure both push rods are loose,put you dist in and were ever your rotor is pointed that will be your number one wire.then you will have to adjust you timing when started by ear,I hope this helps you
Posted on Sep 10, 2009
SOURCE: Farmal C won't go in gear while running, grinds
i have a mtd 38 inch cut wont start floods out the air cleaner can you help me
Posted on Sep 24, 2009
bargainbin2
  • 123 Answers
SOURCE: can't get battery out because too much stuff is in
I am almost sure that battery is on a tray that swings out to the side to remove the battery. So it should not be so hard to remove it.
Posted on Nov 04, 2009
  • 51 Answers
SOURCE: NEED TO KNOW HOW TO TIGHTING STEERING ON 140 tractor
if all tie rods are tight the steering box has a philips screw with a jam nut loose nut turn screw in until it stops, back out a little tighten jam nut. that takes slack out of worm gear. hope this helps
Posted on Aug 01, 2010
2010 crf450r jumping outta gear from 5th to 4th all other gears work fine
Terrence >>>> 1. Do not go through the gears while idling on a stand!!!
The rear tire is not moving at the speed that is normal for 4th or 5th gear..AND if you do get the tire moving that fast.. it is BEYOND DANGEROUS!!
This sounds like the 4th and 5th gears may need replacing.. or the shift drum detent for 5th gear has somehow become ineffective.. If you continue to ride this bike , you may cause more trouble and damage to the transmission.
Take this to a qualified professional!!
Jun 24, 2017 | Honda Garden
Have a farmall super c when the guy repainted it he power washer the old grease and dirt out from the fly wheel now after i start it i cant get it into gear
worked on a farm-all not too long ago and soundslike he may have knocked something into the yokes or knocked something loose. pull the inspection plate off the front of the trans housing and see if it is jambed or loose up in there.
Sep 14, 2010 | Farmall Tractor A-i,av,super A ,super Av...
Farmall a tractor runs but makes a popping sound thru the intake pipe. The tractor hasn't been run for many years.
Possibly a timing issue. Check the timing first. Also check the compression to verify both are within spec
May 04, 2010 | Farmall Tractor A-i,av,super A ,super Av...
Which cylinder is #1 on a Farmall Super C....toward the radiator or toward the steering wheel.....
The radiator. All in line engines always have the #1 cyl closest to the harmonic balancer / belt pulley.
Apr 11, 2010 | Farmall Tractor A-i,av,super A ,super Av...
I have a 1957 farmall A. It is in very good shape and normally starts right up, however. I was attempting to start it after the winter season and the starter just seem to quit after the engine didn't start...
The brushes have more than likely failed in the starter. You can try using a set of VERY "heavy duty" jumper cables directly to the armature side of the starter solenoid making sure the tractor is out of gear. (Ground anywhere on the engine positive to the aramture lead nut) If you get the same hum.... it is time to either get a new set of brushes or replace the starter. Just make sure there are 2 people present so if the positive lead welds itself to the starter someone can disconnect the other end from the battery.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Farmall Tractor A-i,av,super A ,super Av...
The transmission on my 560 Farmall is stuck in gear how do i get back in neutral?
loosen the bolts around the gear shift and put the shifter back into the slot that is not lined up in the center usually it just slipe out and you cant change gears even if it feels like you are.
Nov 26, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
No spark
Im going to ask a stupid question here, is the rotor in the cap?
Jul 15, 2009 | Farmall Tractor A-i,av,super A ,super Av...
I have one that has the same problem,I split tractor to repace rear main clutch an preasure plate,my throw out bearing was bad and the shaft was rusted and would not let the throw bearing go all the way in to the preasure plate
Jun 24, 2009 | Farmall Tractor C ,super Av, Complete...
Farmall Tractor Av-1,super C,100,130,200 Radiator Logo
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
