Question about Toshiba Satellite A75-S209 Notebook
Where is the water pump located on a 1988 Toyota Celica
  • 2,478 Answers
Help this helps.where is the water pump located on a 1988 Toyota C - 2_16_2012_10_55_49_pm.gif
Posted on Feb 16, 2012
Where is the fuel pump relay located in a 93 toyota celica gt?
where is the fuel pump relay located in a 93 toyota celica gt?
Nov 17, 2010 | Toyota Celica Cars & Trucks
There is water leaking from the water pump housing and it looks like a prefabed (manufactured) hole. What can I do to close that hole? This is a 1993 Toyota celica gt
the hole is there to let you know that the water pump is defective, you need a new water pump, normal this hole is filled with wax, when the pump over heats due to the bearings wearing out the wax melts,
Mar 19, 2010 | 1993 Toyota Celica
Where is the timing belt located on a toyota celica?
Assuming your Celica has a belt and not a chain (made from 1988 to 1999,) the timing belt is located behind a plastic cover on the right (passenger) side of the engine. It is not one of the belts that you can readily see; it is hidden behind a protective cover and you have to take off this timing cover as well as the alternator, A/C and power steering belts to get to your timing belt. You will likely also have to remove your right side engine mount. This is a three to four hour job when a mechanic is doing it; it will take someone uninitiated quite a bit longer.
If you are asking where it is located so you can inspect it like the owner's manual tells you to, don't bother. A timing belt that is three months old looks like one that is three years old; the only thing you would be able to tell is if failure were imminent - by looking at the roots of the teeth on the belt to see if the teeth are starting to separate from the rest of the belt. All other observations about the belt are not relevant to an evaluation of its condition; the only exception would be if the belt is getting coolant on it from a failing water pump. On most Celica engines, the timing belt drives the water pump as well as the camshaft.
To have it replaced is a multi-hundred dollar job; how many hundreds depends upon how thorough a job you want done. Timing belts are good for five years or 60,000 miles, so it is prudent (though not strictly necessary) to replace all of the pieces that might fail in the next five years and kill your timing belt - and your engine with it. These things include the timing belt tensioner and/or idler pulleys, water pump, and crankshaft and camshaft oil seals, and maybe the valve cover gasket (some Toyota engines.) Doing these things is foolish if you are planning on selling the car soon; not doing them is foolish if you plan to keep the car for more than two years.
Nov 16, 2009 | 2002 Toyota Celica
Toyota Celica gts 2000 blowing cold air when heater is on.
nothing try back flushing heater core, they clog up due to litle water preasure,you might want to flush cooling system if you already havent, hope this hleps.
Oct 06, 2009 | 2000 Toyota Celica
I cant find my starter in toyota celica 1988
look under intake manifold under car or under exhaust manifold it could be in the rear of the engine or in the front but check those places.
Jul 05, 2009 | 1988 Toyota Celica Liftback
Power window will not go up on a toyota 1995 celica
Usually in the fuse box kick plate next to driver's lower footwell or passenger side, depending on which country you're in.
Apr 04, 2009 | 1988 Toyota Celica Liftback
98 Celica overheating problem
c7d7b55.jpg Cooling Thermostat.
Look along the radiator hose where it enters the engine. This controls the water temperature.
toyotacelicathermalfanswitch.jpgToyota Celica Thermal Fan Switch The Toyota Celica thermal radiator fan switch is usually located in the radiator or the engine block and has 2 or 3 wires coming from the unit. The 3 wire switch has a dual sensor for dual speed radiator fans. The Toyota Celica thermo fan switches come in the factory temperature settings and also come in cooler thermostatic settings so the fan will come on at a lower coolant temp.
The Toyota Celica cooling system is made of aluminum components and requires a Phosphate free coolant. DO NOT PUT an over the counter antifreeze in your Toyota Celica, as it will ruin the radiator and water pump.
Feb 19, 2009 | 1998 Toyota Celica
Replacement water pump 1988 celica gt
yes the timing will have to be reset
Dec 19, 2008 | 1988 Toyota Celica Liftback
How to set timing on 1988 celica?
Under the hood, locate the diagnostic connector. Open the plastic cap, and look under it for the locations of the following pins: T and E1 (TE1 if you have a Calif spec car and E1). Using a paper clip, jump the two pins together. Hook up your timing light and set the timing to 10 degrees BTDC. Then, remove the jumper wire. Easy.
Jul 18, 2008 | 1988 Toyota Celica Liftback
Toyota celica 2.0gt
it sounds like your head gasket unfortunately
May 23, 2008 | 1995 Toyota Celica
Open Questions:
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
