Question about Canon imageCLASS D1180 All-In-One Laser Printer
MY CANON IMAGE CLASS D1180 IS DISPLAYING AN ERROR MESSAGE HOW DO I CLEAR IT?
  • TONY FUENTES Feb 16, 2012
    IT STARTED WITH PAPER JAM NOW ERROR WILL NOT GO AWAY ANY SUGGESTIONS. THANKS IN ADVANCE
  • 628 Answers
SOURCE: canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Posted on Dec 10, 2008
gremlin11
  • 78 Answers
SOURCE: error message wrong cartridge
Rover,
There in is the problem, these cartridges are not made to be refilled. You are lucky to have got away with this for this long. The most likely scenario is that your printhead has now failed which is why it will not recognise your cartridge.
The first thing you might try is to go out and buy a new cartridge. If this fails, then you will need to replace the print head. In this case, you would be better off calling it quits and getting yourself a new printer.
I am sorry if this is not all that you want to hear, but that is the facts and I would be doing you an injustice to tell you otherwise.
Gremlin11
Posted on Dec 13, 2008
  • 1126 Answers
SOURCE: Canon Laser Class 730i Printer/Fax -- Error Code/Alarm E004. How do I clear it?
E004 Fixing Unit Failure.
I would recomend calling repair Tech to resolve this issue....unless you know how to access service mode and perform a Printer Reset operation. Could be complete Fuser Unit failure.
Posted on Jun 03, 2009
canontech
  • 1219 Answers
SOURCE: canon image class copier
Internal Components 2
Subject:
Prevention of blank image (modifying the shape of the laser shutter and applying grease to the laser shutter arm)
Detail:
<Symptom>
Since the laser shutter [1] is not opened when the toner cartridge is inserted into the machine, a blank image is output in
some cases.
[1] Laser shutter
[2] Laser shutter arm
<Cause>
When the toner cartridge is inserted, the laser shutter arm [2] pushes down on the laser shutter [1]. In case that the arm has
a scratch on its sliding surface, however, it is caught in the area [3] where the arm comes into contact with the shutter,
preventing the shutter from being opened.
Service Bulletin LBP-FAX/LBP-MFP
HARDWARE
Issued by Canon Europa N.V.
MF6500-014 Rev. 3
(2/4)
[A] View of the closed laser shutter [1] Laser shutter
[B] View of the opened laser shutter [2] Laser shutter arm
[3] Area where the arm is caught
<Factory measures>
a. Modifying the shape of the laser shutter
Modify the shape of the laser shutter so as to prevent the shutter from being caught when the laser shutter arm pushes it
(A turnback is added to the edge of the area that contacts the laser shutter arm).
P-3 Laser shutter [A] Old type
[B] New type
b. Applying grease to the laser shutter arm
To decrease the sliding resistance of the contacting surface (P-2 [3]) of the laser shutter arm and laser shutter, apply grease
to the laser shutter arm.
P-4 Laser shutter arm [1] Grease application area
MF6500-014 Rev. 3
(3/4)
c. Changing the shape of the laser shutter arm and applying grease to it.
To decrease the sliding resistance of the contacting surface of the laser shutter arm and laser shutter, change the shape of
the laser shutter arm. Additionally, apply grease to the arm.
P-5 Laser shutter arm [1] View of the rib in the new position
[A] Old type [2] View of the new shape of rib
[B] New type [3] View of the arm from which the rib is removed
d. Discontinuing application of grease to the laser shutter arm.
It was confirmed that the new shape of the laser shutter and laser shutter arm do not need lubrication by grease for normal
operation. From this, application of grease is discontinued.
Service Work:
When the foregoing symptom occurs, replace the laser shutter with the new type. In addition, remove the laser shutter arm
and apply a rice-grain sized amount of grease (PERMALUB G No. 2); about 30mg) evenly to the area [1] shown in P-4.
As for a machine having one of the serial numbers listed in “Affected Machines” below as “machines for which the shape
change of the laser shutter is carried out”, only application of grease is required: there is no need to replace the laser
shutter arm because the new type shutter has already been mounted onto them.
When replacing with the new type of laser shutter arm, there is no need to apply grease to it.
Service Parts:
No. Part No. Part Name Q’ty Stock Compatibility
Available
from Fig. No.
O FC6-7328-000 SHUTTER, LASER 1 > 0 1 N FC6-7328-020 SHUTTER, LASER 0 > 1 DC NY In stock 102
2 ON CK-055 1-020 LUBE, PERMALUB G NO. 2 0 > 1 F In stock -
3 ON FFCC66--77333311--000200 AARRMM,, SSHHUUTTTTEERR,, LLAASSEERR 10 >> 01 DC YN In stock 102
Affected Machines:
- Machines for which the shape change of the laser shutter is carried out
LaserBase MF6530 EU1 SNF50048 and later
LaserBase MF6550 EU1 SNG50009 and later
i-SENSYS MF6530 EU1 BAC02001 and later
i-SENSYS MF6550 EU1 DAC02001 and later
LaserBase MF6540PL EU1 SNP50288 and later
LaserBase MF6560PL EU1 SNQ50001 and later
LaserBase MF6580PL EU1 SNR21266 and later
i-SENSYS MF6540PL EU1 EAC02001 and later
i-SENSYS MF6560PL EU1 FAC02001 and later
i-SENSYS MF6580PL EU1 GAC02001 and later
LaserBase MF6530 EU2 SNX50504 and later
LaserBase MF6550 EU2 SPB50568 and later
LaserBase MF6540PL EU2 SPC50196 and later
LaserBase MF6560PL EU2 SPD50012 and later
LaserBase MF6580PL EU2 SPF50288 and later
LaserBase MF6550 EU3 SPG50312 and later
MF6500-014 Rev. 3
(4/4)
LaserBase MF6560PL EU3 SPH50444 and later
LaserBase MF6580PL EU3 SPJ50384 and later
i-SENSYS MF6530 EU2 HAC02001 and later
i-SENSYS MF6550 EU2 NAC02001 and later
i-SENSYS MF6540PL EU2 PAC02001 and later
i-SENSYS MF6560PL EU2 QAC02001 and later
i-SENSYS MF6580PL EU2 SAC02001 and later
i-SENSYS MF6550 EU3 VAC02001 and later
i-SENSYS MF6560PL EU3 WAC02001 and later
i-SENSYS MF6580PL EU3 XAC02001 and later
- Machines for which both the shape change of the laser shutter and application of grease to the laser shutter arm is carried out
i-SENSYS MF6530 EU1 BAC02945 and later
i-SENSYS MF6550 EU1 DAC02865 and later
i-SENSYS MF6540PL EU1 EAC04003 and later
i-SENSYS MF6560PL EU1 FAC03073 and later
i-SENSYS MF6580PL EU1 GAC02833 and later
i-SENSYS MF6530 EU2 HAC02049 and later
i-SENSYS MF6550 EU2 NAC03737 and later
i-SENSYS MF6540PL EU2 PAC02633 and later
i-SENSYS MF6560PL EU2 QAC03593 and later
i-SENSYS MF6580PL EU2 SAC02105 and later
i-SENSYS MF6550 EU3 VAC03185 and later
i-SENSYS MF6560PL EU3 WAC02665 and later
i-SENSYS MF6580PL EU3 XAC03025 and later
- Machines for which the following are carried out: change of the laser shutter shape, applicatin of grease to the laser
shutter arm, and change of the laser shutter arm shape
- Machines for which the following is carried out: discontinuance of application of grease to the laser shutter arm
i-SENSYS MF6530 EU1 BAC02946 and later
i-SENSYS MF6550 EU1 DAC03161 and later
i-SENSYS MF6530 EU2 HAC02121 and later
Posted on Jan 19, 2010
pineworks
  • 4041 Answers
SOURCE: system error e225
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Posted on Apr 28, 2010
What is Canon printer Pixma MP560 error U052?
Canon printer class action suit
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Jul 03, 2014 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
How to fix u052?
Error U052 = Please check that print head contact pins of the carriage are not bent.
Or else you may need to replace
- Print head
- Carriage Unit
Jun 29, 2014 | Canon MG5150 AllInOne Printer
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
Canon pixma mp630 error u052
FYI, Canon inkjet printer class action suit
Mar 29, 2012 | Canon PIXMA Office Equipment & Supplies
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon pixma mg5220 wrong printhead error u052
Were you aware of the Canon printer class action suit?
May 24, 2011 | Canon Pixma MG5220 InkJet Printer
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
Canon image class mf6550 erroe E000
This is normally caused by a power dip.Reset it by pressing the usermode star and then # key.On the display sssw1 will display.Scroll to clear and press ok select the error and press ok.Switch the machine on and off.If this does not help the fixing unit is damage.
.g_thread_answer { overflow:visible !important; }
Dec 14, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Error E078 Canon MF8180c
I have a Canon Color Image Class MF 8180C with a system error code E078 - Trying to understand what it means and how to clear. Any ideas?
Jun 05, 2009 | Laser Canon imageCLASS 8180C Multifunction...
Check printer in canon image class d760
kindly explain what u did when it mentioned that error ?
Feb 07, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon imageCLASS D1180 All-In-One Laser Printer Logo
old marine
old marine
