Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
Projection is too close cuts the screen what do i do
The whole screen is cut short. top, bottom, left and right. we have had it for some time now and the screen would cut out if the screen was a still picture.
  • John Husk
    John Husk Feb 16, 2012
    I have messed with all the picture settings nothing makes it better just worse.
Have you tried zoom setting in the menu? wide, full , or zoom?
Posted on Feb 16, 2012
Dell inspiron right hand margin cut off
It is more likely that the window got moved to a point where the x, restore, and minimize buttons don't show than it is that a portion of the whole desktop is cut off. Right-click on the icon that represents this window in the task bar, and click maximize. If that's not an option, choose move, and then use the down and or left arrow keys to reposition the window where you can see the minimize, restore, and x buttons, and then hit enter on the keyboard.
Mar 02, 2012 | Computers & Internet
The display of start button and all the short cuts upside down and is on the top right hand corner ot the screen
In order to move the Taskbar (that is the where the start button is located) all you need to do is left click on an open area of the task bar and drag it down to the bottom of the screen. When you release the left mouse button the Taskbar will appear at the bottom of your screen.
Apr 01, 2011 | Amstron Toshiba Satellite Pro P200-19R...
How come the top and sometimes the bottom of my screen are cut off
Not all bradcast are in 16:9 resolution (wide screen). Most are still in 4:3 (old TV).
Sometime the advertisements are in 16:9 letterbox to project correctly on 4:3 TV and TV logo or titles are on the bottom or top of the picture. If TV is set to project wide screen, these logos or writings will be cut off.
If you have an option to switch TV resolution from remount, you will see whole picture.
Check your TV manual for settings.
Dec 20, 2010 | Panasonic TH-42PX20U/P 42 in. HDTV Plasma...
Need a copy of page on setting up the Craftman miter saw model 113235120. There is one page in there with the set up to cut compound miters.
Make all cuts with molding flat on the table and bevel at 33.8 for ALL cuts ...to cut left inside corner, set miter at 31.6 degrees right. top of molding against the fence left side is finished piece... right inside corner set miter at 31.6 left with bottom of molding against the fence.left side is finished piece...left outside corner same setting, bottom of molding against fence right side is finished piece...right outside corner set miter at 31.6 right with top of molding against fence. right side is finished piece. hope this helps
Sep 01, 2009 | Craftsman Saws
We have a widescreen plasma (Panasonic TY ST05-K). The picture all of the sudden shrunk to about 3/4 of the screen. Fortunately, the picture is not cut-off, so you can see the whole picture. The...
Hi there! If picture is smaller top to bottom with blank section on top and bottom then check your aspect ratio settings. If blank at the bottom only the Bottom Y-Drive board may be faulty. If blank at the top The Top Y-Drive may be faulty. If blank on the Left (TOP TO Bottom) then the Right X-Drive Board and on the Right, the Left X-Drive Board. May also be bad connections on the cables or flexible ribbon cables. Best Wishes and Good Luck, JUS004
Aug 23, 2009 | Televison & Video
Picture jumps
you might have bad caps or the vertical output integrated circuit, try to locate the vertical ic and check the surrounding areas for bad capacitors.
good luck
caypianan@yahoo.com
Oct 23, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Samsung 61 inch issue
for clarification, may i know the model # of your TV? and do you have a problem on the sound
Sep 29, 2008 | Samsung 61" Slim-Depth LED DLP HDTV
RCA HD52W19
try this go ipress menu goto picture then advance setings and make sure autoformat is not on then you can push the arrow left or right on remote to change format.
Aug 02, 2008 | RCA D52W19 52" Rear Projection Television
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Unable to see scores
you have to hit aspect on the remote until it fits the screen right
Jan 14, 2008 | Hitachi 51G500 51" Rear Projection...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
