Question about Whirlpool LSB6000PQ Top Load Washer
Removing a whirlpool timer dial?
I have a whirlpool LSQ9600LG0 (extra care plus) washer with a broken timer dial. I cannot figure out how to remove the knob and dial. I have tried unscrewing, I have flipped the control panel back to see if there's a release or clip, and there isn't (everything I can find online says it should be a small black clip). All I can see (besides the timer and such) is a round metal thing, looks like the end of a bolt. Nothing that could be holding it from coming out, I wouldn't imagine. Just looks like the end of the peg/screw that should hold everything on. Any ideas, or a 'hey idiot, this is what you're supposed to do' suggestion?
  • Official Brand Answer
  • 380 Answers
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_reviews@Whirlpool.com for further assistance. Please proivde your full name, address and the model and serial number for your washer.
Posted on Apr 18, 2017
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: whirlpool duet washer model GHW9400PWO
Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top
Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer and pulling it completely out of the washer.
Once the drawer is removed, remove the screw in the recessed hole next to the drawer opening. Release the tab securing the right side of the console to the washer
Open the washer door and place a flat-bladed screwdriver into the slot in the bottom center of the console. Push the console up to release center console tab. Be sure the ribbon cable clears the cabinet frame.
Removing the Touch Pad/LED Assembly from the Console
The Touch Pad/LED Assembly is removed as a single unit and contains the Push Buttons, LEDs, cable, etc. The buttons can be replaced separately
Posted on Oct 05, 2008
scottowa
  • 87 Answers
SOURCE: how to remove back & top of a whirlpool ultimate care II washer
I'm not sure of the model number of the stove but usually slide a putty knife under the control panel between the bottom of the control and the top of the base. There is a clip on each side then the panel will tilt back and you can take it off. After that there are 2 gold clips that hold the back on to the base. Remove them by snapping then out of the base. The the whole thing is loose and the base (where the lid and sides are. Comes out as 1 big piece. If you get the model number from under the lid, you can go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears
and it will show you a breakdown of the machine. Let me know if you need anything else.
Posted on Mar 29, 2009
  • 57 Answers
SOURCE: Kenmore/Whirlpool Washer - How to remove console End caps?
its probably the half load button is stuck in the on position inside the switch replace
Posted on Jun 23, 2009
  • 20 Answers
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
Posted on Sep 13, 2009
I want to replace a timer on a Whirlpool washer Model# LSN1000KQW
Good day Mr.james dant..
Whirlpool manufactures many types of washing machines. Whirlpool's top load models rely on an analog timer that controls the cycle used to wash the clothes in the washing machine, rather than a digital control board found in most front load models. The timer contains a number of moving parts and is physically turned to choose the wash cycle. Because of the high usage of the timer, it will eventually break, requiring replacement. Rather than calling a service technician to repair the timer, replace the timer yourself to save both time and money.
Instructions
1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the timer. To unscrew, hold the dial with one hand and turn the knob counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position. 5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees.
6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer
9. Place the dial back onto the timer post and then screw the knob onto the post.
10. Plug the washer back into the wall outlet
Try to watch this video:
Nov 25, 2011 | Washing Machines
Have a 10 year old Whirlpool Ultimate Care II top loading clothes washing machine. In the "Delicate" cycle, it stops after agitating sometimes and will not kick into the spin empty part of the...
Yes it is a timer issue, and yes the whole timer will need to be replaced. If you are handy it is not very hard. You can order the timer from marcone.com with your model # and it will show you a parts breakdown so you can see hoe to replace it easier
Nov 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Replaced door/lid switch now...after finald spin cycle the washer starts next cycle on dial
Bad Timer, you may have had a power surge damage both componets at the same time. (Make sure you aren't using the extra rinse cycle)
Appliance Specialists
Dec 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not change cycles on its own
timer is most likely bad if it will not move on its own at all..
3951703 - TIMER
you can access the timer by:
remove power from the unit.
remove the philips head screws that should be present in each left and right control panel end cap front.
slide the control panel bottom forward 1/2 inch and lift up.
the entire console will swing up on the hinges in the rear of the console top.
with the console upside down you can see the back of the timer, there is a small brown clip sort of recessed into the back of the timer that is connected to the timer knob/shaft. that clip needs to be pulled out so that the knob can be removed to access the screws on the front to remove the timer assembly.
around $100 new
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
How do you remove the timer on a Whirlpool washer
You have to unscrew the knob and remove the screws that are under it, some have just a center nut with a locating tab that goes into a hole to hold it straight.
Oct 24, 2009 | Whirlpool Washing Machines
We have an Kenmore 70 Series Heavy Duty Plus washing machine that is about 20 years old. The washer stops after the wash cycle and we have to manually move the dial one notch. The washer then completes the...
This is the deal, your washer is way to old to fix. The board is going bad and that is why it will not cycle properly. It would cost about $150.00 to fix and that does not even include labor. Consider craigslist as you can find some great deals from 40-60 for a newer one. Hope this helps.
JimmyC
Sep 26, 2009 | Kenmore Washing Machines
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Howdo i get the washer cover off a thintwin whirlpool washer tha
the timer box or the whole washing cabinet cover?
the timer box is removed via 2 screws in the rear of the plastic end caps and carefully wiggling it foward very gently then it should tip back...
if you want the cabinet removed under the timer box is 2 metal snaps that can be removed to take off the outter cabinet.. good luck
Feb 15, 2009 | Whirlpool LSB6200PQ Top Load Washer
No hot or warm wash cycle
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2009 | Washing Machines
Whirlpool LSB6000PQ Top Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
