Question about HP Computers & Internet
My new hp w2207h monitor, pop up keep telling me to install driver. when i install driver a error message comes up.what should i do.
  • compgeek09 May 11, 2010
    What opererating system are you using? XP or Vista? What is the error message?
    Scholar:
  • 80 Answers
Go to - CONTROL PANEL - DEVICE MANAGER then find monitors in the list,right click the desired device, then PROPERTIES this will tell you if the device is working properly. then click update drivers. If this fails check your screen resolution settings. The safest thing is to set it to default.Sometimes the graphics card isnt big enough for the monitor so try tweaking visual settings like shadows and fonts. Things like message box outlines and shadows can be turned off too speed the image up.If your using vista your probably using the default theme AERO/GLASS. Change it to a normal theme of your choice but dont use GLASS. this uses quite alot of graphics power.
Posted on Oct 25, 2008
My HP L1730 Model PE1238 17 inch lcd monitor wont switch on. it makes a sound every couple seconds. it sounds like it does when its coming on but its cut short fix please ?
How to repair HP Pavilion f1703 lcd monitor - YouTube
? 5:48
https://www.youtube.com/watch?v=rFXyIMAq64o
Jul 11, 2010 - Uploaded by z28r2fast4u
How to repair HP Pavilion f1703 lcd monitor. ... 17:38. HP L1750LCD monitor repair - Also applies to ...
HP W2207h LCD MONITOR-HOW TO TURN OFF OSD ...
h30434.www3.hp.com > ... > Video/Touch
Solved: MY EXTERNAL, HP W2207h LCD FLAT SCREEN MONITOR OPERATES FINE WITH ... HP ENVY 17t Touch,i7-5500u,16GB, 256 GB SSD (on loan)Missing: l1730 ‎pe1238
Using and Adjusting Your Monitor - HP Customer Support
Dec 25, 2015 | HP Computers & Internet
Hp w2207h
Try a monitor reset. Power off the PC and monitor. Unplug the monitor and hold down the monitor's power button for 30-60 seconds. Plug the monitor back in and then power up the system.
See this... http://h30434.www3.hp.com/t5/Desktop-Audio-Video-Monitors/HP-w2207h-monitor/td-p/222913
Jul 10, 2014 | Computers & Internet
I have an HP w2207h monitor. On some programs the image is too large for the monitor so that the image and text disappear off the right side of the screen. Could you recommend a solutiion please. Thank...
The HP w2207h monitor comes with an Installation Disk (CD)
It has the Drivers on it.
Have you used it yet?
If not pull the disk out, put it in your optical drive (CD/DVD drive), and load the contents.
After it has finished loading restart your computer, if not asked to do so.
When Windows has fulled loaded again, right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
Now click on the Settings tab.
Look down at Screen Resolution in the middle. Is the resolution what it should be?
The native resolution?
If not left-click on the slider, hold the left mouse button down, and move the slider left, or right, until the native resolution is what it's supposed to be.
[The slider is the down arrow looking icon on the line in-between Less and More]
Go down to the bottom right, and click on Apply.
Now down to the bottom left, and click on OK.
The native resolution for the HP w2207h is 1680 X 1050 (Pixels)
Should be set to 60 Hertz also. (60Hz)
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01182749
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 04, 2011 | Computers & Internet
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
My Realtek speaker system, which came with the computer just stopped working. I've been on the phone for hours with Micrsoft trying to fix the problem to no avail. HELP!!! Microsoft has been trying to...
HP has released a patch for AMD based systems. It requires a patch download that must be installed prior to installing the XP SP3 update.
I hope this at least gives you an answer-not one I'm sure you want to hear. good luck
please leave a rating...thankyou
link below
Link to HP patch:
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-60484-1&jumpid=reg_R1002_USEN
May 05, 2009 | Computers & Internet
My hp w2207h goes to sleep
Sounds like your video card is failing. If the video is internal to the motherboard, get a video card and add it to the motherboard if there is an open video slot available
Mar 13, 2017 | HP Computers & Internet
Vison Monitor ( device installer error)
First you need to uninstall the driver for your old monitor. Then install the driver for the new monitor. With both drivers installed your computer is confused and shows the conflict as an error message. Hope this helps.
Dec 23, 2008 | Computers & Internet
My Monitor is an HPw1907 and I downloaded an update for it and my computer(hp/a6610t) keeps giving me an error notice and aborts the installation.
I get the message, An error occurred while installing the display drivers. when trying to install monitor driver software.
Nov 23, 2008 | HP Computers & Internet
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
Computers & Internet Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
