Question about Maytag Refrigerators
I have a MFI2568AEW not cooling. A door was left open a few hours. After closing it stop cooling. I unplugged it for a few hours then replug NO COOLING! . I saw on utube on the same scenario and he said most likely the thermostat so I changed it ,NOTHING COOLING! I NEED HELP!
  • maddmaxx71 Feb 23, 2012
    I'll change the compressor relay still no coolant low low low on air blowing from the top frig.
    President:
  • 2,468 Answers
The ptc overload on the compressors bad,unplug the unit,remove the ptc off the side of the compressor and purchase a new replacement and it will again cool,this part is what starts and operates the compressor
Posted on Feb 17, 2012
    It didn't work, i can feel the compressor running,still no COOLING! . The air in the top frig.is blowing very low.
3 Suggested Answers
dnewcombe1
  • 1564 Answers
SOURCE: Refrigerator refuses to cool or freeze
Pull the base front panel off. Inside using a flashlight look for a small motor abnout the diameter of lashlight and about one and a half inches tall. This unit will have a slot for a large flatblade screwdriver. Turn the slot (CLOCKWISE ONLY) until you hear a slight click. If your fridge fires up than you need a new "Defrost timer" if it does not than you've got bigger problems. Give the test about ten minutes time then feel the freezer walls, they should be cold. Thank you, Dana
Posted on Jan 06, 2010
allbrands
  • 600 Answers
SOURCE: My maytag model MFI2568AEW serial
Hello, Thank You for using FixYa. I will be helping you today.You have to replace the hv control board on the back of the unit. if that is your full model number and there are no numbers after it then its part number #: 12920710 Im sure this is it we replace them all the time.
Thank You and please rate my answer if it was helpful..
Posted on Jun 13, 2011
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
Hotpoint FZFM171 freezer door left open all night, has defrosted and the 'super freeze' light and alarm light wont stop flashing. How do we fix it?
Turn the power off to the refrigerator and manually defrost the freezer until the freezer bis no longer cold and then replug the power cord
.APPLIANCE 911
Jan 27, 2016 | Hotpoint Refrigerators
Freezer door was accidentally left open for about one hour. Now the refrigerator and freezer are not cooling.
If the freezer or fridge door remains open for one hour or few more hours by mistake, then to again get to its proper cooling cycle, it requires approx another 24 hours.And in that also, dont open the refrigerators doors for few hours.If you open, close it quickly.Once it cooling cycle again gets set, then you can use it like you use regularly.But approx it takes 24 hours to get proper cooling.-------- ------------------ But if its already more then 24 hours and there is very low cooling, then it can be internal defrost cycle issue.You will have to do manual reset procedure.The manual reset procedure is as follows:-------- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check,it will get set to its cooling cycle and work as normal.------------- This should help.Thanks.Helpmech.
May 04, 2011 | Refrigerators
We have an Overhead garage door. It has started
A bad circuit board or capasitor will cause this, mostly its the circuitboard. Depending on the age replace it with a Chamberlain/Sears opener or they make a model called LIFTMASTER you can only get this thru a garage door company.
May 19, 2010 | General Electric GE 13-438 Overhead Garage...
Refrigerator won't cool
MUST DEFROST LEAVE IT OFF FOR 24 HOURS .
Apr 07, 2010 | Kenmore 57029 Side by Side Refrigerator
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Mayteg refirgerator
French Door “ICE-2-0” Bottom Mount
Freezer Refrigerators with
Ice & Water Dispenser
Maytag Models: MFI2568AEB MFI2568AEQ MFI2568AEW MFI2568AES MFI2067AEB
MFI2067AEQ MFI2067AES MFI2067AEW
Amana Models: AFI2568AEB AFI2568AEQ AFI2568AES AFI2568AEW
cusTOMeR COMPLAINT:
Ice dispenser door continually opens and closes and/or user display flashes on and off intermittently.
cause:
Power supply circuit on high voltage control board may fail.
cORECTION:
Order and install high voltage control board kit PN 12920710. The kit includes; control board, installation and programming
instructions, return label and card for the old part.
Note: As with all Refrigerators of this type, the correct “Personality Code” must be programmed into the new control board
per the instruction sheet provided.
Feb 16, 2008 | Washing Machines
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Samsung RS2556SH Freezer left open. compressor does not come on.
if door was left open for some time, there may be excess ice build-up on the evaporator which may take more than 2 hours to clear. two methods to cure switch off and leave for 24 hours with doors open. or remove back panel in freezer and carefully melt ice off with a hairdryer
Jun 16, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
56 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
