How to attach base to my v1210 plasma tv - Televison & Video
How to get closed caption off v1210 tv?
usually pressing the cc button on remote does it
Mar 12, 2016 | Televison & Video
Where can I buy a remote for a V1210 TV?
Ebay.com type tv model in search bar followed by the word parts
Feb 03, 2013 | Televison & Video
How to put the stand back on a plasma tv
most of the time the set has to be laid face down "safely" so no weight or stress is on the actual front screen---the base then should be safely attached and the 4 or more specific bolts attached.
It can be done with 3 people--2 holding it up and number 3 attaching the base........
Oct 29, 2012 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
NEED A BASE FOR PLASMA TV
Manufacturer LGE Part Number 3501900014B Description BOARD ASSEMBLY
Aug 20, 2009 | LG 42PX5D 42 in. Plasma HDTV
We can't figure out how to remove the base on our new 50" Sanyo Plasma TV so we can hang it on the wall...HELP!
look at the rear of the tv there are four phillips head screws holding the base on unscrew them and lift the base off
Apr 15, 2009 | Sanyo DP50747 50 in. Plasma TV
MOUNTING MY TV ON A ENTERTAINMENT STAND
there is no problem i use the same bolts and it is ok from 2 years ago but for your paceful you can replace with other bolts approx 20 MM long
Dec 10, 2008 | JVC PD-42V31 42 in. Plasma Television
How do we mount our Panasonic Plasma tv on a tv stand?
Panasonic Plasma TVs come with a detachable base. For wall mounting it is not used, but you will need to find and attach it for use on a TV stand.
Nov 30, 2008 | Panasonic Televison & Video
Affixing 42" TV to stand
employ a technical expert to measure the diameter,type & length of the screw to fix.
Oct 11, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
I need to remove the base from my 42 inch plasma TV to mount it onto a TV stand. How do you remove the base?
Good Day;
The base is attached by four, inset, allen screws on the back of the unit, bottom. The 'key' word is INSET (recessed).
Good Luck, Day, Big Irish.
Jun 18, 2008 | Akai Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
