Question about Vizio P50HDTV10A 50 in. Plasma HDTV
How to install the base
How do i install the base to my television and what parts are required
  • 963 Answers
This direct link will take you to the manual for your TV:
http://www.manualowl.com/m/Vizio/P50HDTV10A/Manual/230976
You will need Adobe Reader installed on your computer to view it, since this is a .PDF file.
Page 6 illustrates the removal of the base for wall mounting; of course you need to reverse the process for the base mount.
Posted on Feb 17, 2012
Where can I get a base the took off and lost and now we need one
Sears Parts Direct has some of the parts for the LC320EM9 here: http://www.searspartsdirect.com/partsdirect/part-model/Emerson-Parts/Television-Parts/Model-LC320EM9/0352/0333600/50034435/00001 .
There are three parts to the stand plus a number of screws needed.
The base holder is 1EM222005 (part B9). The stand cover is 1EM122413 (part A9). However this site doesn't have the base plate 1EM122276 (B7).
PacParts may have the base plate: http://www.pacparts.com/part.cfm?MFG=GFM&PART_NO=1EM122276 .
I hope this helps.
(note: Emerson TVs are made by Funai; that is why PacParts lists the base plate as being a Funai brand.)
Dec 05, 2012 | Emerson LC320EM9 32 in. LCD HDTV
How do I take the front screen off my TV to clean dust off
If the model number indicated here is correct do not remove the screen---usually all that is required is to remove the back cover (picture is darker and somewhat dull looking?) and locate the three large black lens at top of chassis---they are the light source for this model---clean with a lens cloth or a paper towel with glass cleaner sprayed on it.
The set (again based on the model number) may have a mirror in the rear upper part but it rarely requires cleaning.
Let me know if questions.
Mar 22, 2012 | Samsung HLP6163W 61" Rear Projection...
How do I remove the base from the TV to mount it on the wall?
See page 9 of the user manual, you need to remove 4 base mounting screws.
You can download the user manual from Sanyo website:
http://us.sanyo.com/dynamic/product/Downloads/DP50747_Manual-31187309.pdf
Please leave rating if it helps.
Jan 09, 2011 | Sanyo DP50747 50 in. Plasma TV
Sony Bravia KDL-V40XBR1. Lost the main screw to the base. The one that secures to the bottom of the base into the tv. What size is it so I can replace it!
Required screws part number is as follows:
258064001.... SCREW +BVTP2 4X16
Available in PartStore.com for $5 each
Hope these info will help you.
Thanks.
Nov 26, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Need a base for a display model i bought at wal-mart
If you are looking for base stand fo Sony KDL-52S5100 then I might help you to provide you part number info to buy it.
All I need is exact model number of your tv that would be written at rear to provide you correct part number of required base stand.
Thanks.
Aug 09, 2010 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
How much clearance is required between the bottom of the built-in oven and the plywood floor of the cabinet
The installation manual does not specify.
(If you need a manual you can get one here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man)
As an installer, without a manufacturer's specification, I would assume no specific clearance is required. Further, if you check the exploded parts diagram in the manual you will note that there is an insulating panel in the base of the oven. Evidently the oven has been designed to insulate the exterior panel from excess heating and does not require any minimum clearance at the base.
Mar 19, 2010 | Frigidaire (FEB30S7D) Oven
Phillips analog TV does not start need to turn on and off several. Require me to turn on and off about ten times to finally start.? Is there a part that I need to change?
You need to replace 2 transistors and 2 small capacitors in horizontal drive circuit. NTE123ap and NTE159 transistors will work but base and emitter pins are reversed from the transistors installed now so they must be turned 180 degrees from originals.
Oct 16, 2009 | Philips Televison & Video
How do you install the base before adding the actual TV? Is the base really just kept together by the weight of the TV itself?
You will find the base should either slot into a rear or uderside section of the TV & is then screwed into the fixing or will have a rear flat part on the back of the TV which again should be screwed in for support.
Oct 14, 2009 | Televison & Video
Hoover Empower Widepath Vacuum Doesn't ****
This model requires the lower end of the hose to be installed into the base unit to pick up the dirt. If it is properly installed, I would check the belt and also look for a blockage. The normal life span of a belt is about 9-12 months. your belt # 40201190 2 pk
Mar 11, 2009 | Hoover U5172900 Fold Away Widepath Bagless...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
124 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
