Question about ION Audio iED01 Electronic Drum Set
I HAVE a idmo2 that is on but no sound
I turn it on and it works but when i play it thirs no sound
CAN'T GET SOUND FROM ION IDMO2 INPUT PADS
And so you decided to ask the turntable experts?
Jan 18, 2013 | Audio Players & Recorders
What does error code E-4 mean?
Hi John:
E4 error code is reref at defrost sensor; in order to solve your problem, contact your service dealer and ask about thir order replacement; this replace sensor job is a simple plug and play.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 15, 2011 | Refrigerators
Unit in safe mode,eject tape and reinsert jvc camcorder model no gr-d270u
the problem is from the mechanism,thir is one flex that has black surface beside the motor of the mechanism, you need to breg it ,then you test the camera
Sep 07, 2011 | Video Cameras
Clutch is bleed but still is about a quater pedal
thir is an adjustment screw on the cable by where it goes into the trans and you can turn it counter clock wise to tighten up the cable
Jul 31, 2011 | 1992 Chevrolet S-10 Blazer
I have a 6 year old 32" Toshiba tube .tv. I have
thir is somecondensers on the tv needs to be changed especialy on pwer supply and vertical circuit it is easy fault but needs technication,,,but first be sure thir is no floresent lamp common with the same supply of the set
Dec 23, 2010 | Toshiba 32A14 TV
Yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
Gateway LX6810-01 wont turn on now
1. how many beep sounds do you here and in what sequence ?
2. please look at the small blinking lit at the back of your pc most of the time thir combination of blinking speeks its problem.
2. check/remove if you install new hard ware on the board
Jun 30, 2010 | Gateway LX6810-01 PC Desktop
I have the ion idmo2 and I can't get the drum set part to work.I don't have instructions I lost in a move, All the rest is working. jamancuso@aol.com
I have the same exact set and module. It is the same module as the Alesis SR-16. I have the manual here but can't find it online, however, here is a link for the SR-16, I hope this helps.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CEIQFjAC&url=http%3A%2F%2Fc3.zzounds.com%2Fmedia%2FSR16_Manual-9d796d56d2c465f19b598d39a29c8d8c.pdf&ei=HkBIUYn2OdKk4AOVnoG4Dw&usg=AFQjCNHjCN7pfLOX9pINxBc_G3s0QrUsRQ
May 18, 2009 | ION Audio iED01 Electronic Drum Set
I have the ion idmo2 and I can't get the drum set part to work.I don't have instructions I lost in a move, All the rest is working. My e-mail jamancuso@aol.com Thanks Joseph
Why not download the .pdf's for it from the manufacturer's page? It's easy!
just go to: http://www.ionaudio.com/contentmgr/showdetails.php/id/1137/tt/4
Then you can save them to your computer and/or print them out.
E N J O Y!
ION Audio iED01 Electronic Drum Set Logo
50 people viewed this question
Top ION Audio Toys Experts
Andrew Taylor
Andrew Taylor
Are you an ION Audio Toy Expert? Answer questions, earn points and help others
