Question about Craftsman 4 Cycle Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
This is a 2 cycle blower. I just replaced the primer bulb and fuel lines on a Craftsman leaf blower. It starts fine but seems to run out of fuel. I can keep it running by pumping the primer bulb every 5-6 seconds. I checked the filter and it is not blocked. Lines are not kinked.
  • Anonymous Mar 20, 2014
    My leaf blower starts fine and for about 10 minutes then it stalls. When I remove the air filter cover, I find the foam air filter soaked with fuel. Do you have any ideas what would cause this?
  • Anonymous Mar 30, 2014
    No gas comes into the primer bulb when I depress it
Sounds like your carb needs cleaned you have a restriction somewhere
Posted on Oct 07, 2012
  • 211 Answers
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
After replacing primer bulb, engine hesitates and will not run full throttle
Make sure you connected the lines correctly. If this is a primer assy that has the 2 barbs on the back here is a picture of how the lines should be connected to it as well as the carburetor
Now if this is a primer bulb on top of the carburetor then disregard the previous answer because in this case, your carburetor needs the H needle adjusted. Go on you tube .com and type in how to adjust a 2 cycle carburetor. Many videos will appear.
Nov 21, 2015 | Garden
Hello, I have a sears leaf blower (358.794762) that will not start. It's almost like the primer bypasses the carb
Sounds like your fuel filter is plugged. Bend a hook on a piece of wire and fish the filter out of the fuel tank. Remove the filter and see if you can blow through it. If not replace the filter. Good luck.
Nov 19, 2015 | Garden
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Ryobi instruction manuals
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
Will not keep running unless the choke is partly on
Tuning/carb/fueling problem. Check primer bulb and fuel lines for air leaks. clean and service carb
Dec 04, 2012 | Husqvarna Hand Held Blower 125 B Grass...
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
How do I replace the fuel bulb?
Homelite and Ryobi appear to be made by the same manufacturer. Home Depot now carries a "Fuel System Tune-Up Kit, AC04122," that includes 2 replacement fuel lines and a replacement Primer Bulb for 25cc, 30cc, and 26cc 2-cycle engines. Cost is $7 +.
Aug 27, 2012 | Homelite Mighty Lite Blowervac
Craftsman 4 Cycle Blower/Vac Logo
1,685 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
