Question about JVC KD-SH77 CD Player
JVC KD-SH77 Head Unit
Ok, the head unit has three pairs of outputs, front,rear,and subwoofer. Front and rear work fine but when i try the subwoofer output, nothing. Thanks for any help.
  • 1113 Answers
SOURCE: how set time jvc kd g220
Hi - You can download the manual from the link underlined in blue below:
jvc kd g220
See page 10.
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 21, 2008
  • 55 Answers
SOURCE: jvc kd-sh55 head unit
Have you tried pressing the "RESET" button on the stereo? I have a JVC unit in my car and the reset button is a tiny hole behind the detachable face. Take a pencil or a pen and insert the end into the tiny hole an hold for a few seconds. This will reset the stereo and you should be able to eject the CD as you normally would. If it's a mini-disc (8mm) you probably would have to take the unit apart and manually retrieve it - big hassle. Check the owner's manual to find out where the "RESET" button is if it is not behind the face. If you don't have the owner's manual, you can download one from Hope this helps.
Posted on Aug 30, 2008
  • 3 Answers
SOURCE: problem downloading
Follow this link to the how to instructions.
Then go the next link and download the (Image Converter wide 1.2), version, now remember it takes time to load onto your player, 90 frames might take 4 minutes. I’ve done this and it works but you have to set your player settings to user options it helps to have the Instruction manual handy.
Instruction manual is at this link.
Posted on Nov 12, 2008
SOURCE: jvc kd-pdr30 ipod problems
The Touch will not work with the KDPDR30. I spoke with JVC and their models that will operate the Touch are KDPDR40, KDAPD49, KDPDR45, KDPDR41 and KDG47 the last two have a cable required.
Posted on Mar 02, 2009
  • 655 Answers
SOURCE: Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Posted on Jun 06, 2009
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
0 characters
1 Points
How do I remove the JVC KD-G635 car stereo to gain access to the rear of the unit.
u need special tools to remove the head unit if it was installed right. security purposes
I have jvc car audio model # kd-g335 how to connect my sub woofer?
You can not connect the subwoofer directly to your head unit. You need an amplifier installed to play the sub woofer. Asuming that there is an amplifier installed then: If your head unit has an RCA output on the rear, connect that to the LINE IN of your amplifier. Also there should be a Blue&White cable at the rear of the head unit.(amplifier remote) That should be connected the the remote terminal on the amplifier. (this will turn the amp on and off when the head unit turns on or off) Hope this helps. dreamsystems
Feb 08, 2011 | JVC KD-G340 Car CD/ MP3 Player
Is there a way to link a JVC Kameleon head unit with my stock CD changer? I have a mercedes slk350, just replaced the audio 20 head unit with the JVC Kameleon. Everything works and looks good, but I want...
The only thing i can suggest is to go to your audio shop and ask the same question to them, as they normally carry many different styles of leads and may have one there that will help you to connect your cd player, Is there a din output on the back of this unit? if so they should be able to help.
Feb 21, 2010 | JVC KD-G310 CD Player
JVC In-Dash CD player KD-HDR30
no its not to new its starting to have problems.JVCs arent known to llast maybe 2 years get a good pioneer youll be happier.
Nov 07, 2009 | JVC KD-HDR30 CD Player
Unmarked wires
your jvc is pretty standard on hook wire is on a keyed power wire,black is chasis ground, blue is remote wire to amp.yellow also keyed power wire.speaker wires there will be 8,usually whit violet so on. white solid for exzamle is + white with black stripe is - you can figure out front and rear with an old speaker and buy fading front to rear on your head unit youll know front and rears.same for left and right.did you look on the unit usually the have the wiring diagram on the unit itself.mine all do
Jun 21, 2009 | JVC KD-S580 CD Player
Playing my Ipod through a JVC-S733R, Best resuls
Hello bob2154,
Well, best and cheapest are mutually exclusive.
The best way would be to replace the head unit with perhaps the newer JVC KD-DV5400 which does have an aux input on the front. If you order from Crutchfield and use my referral number, you'll save $20 and shipping is free.
If you want the cheapest way, I recommend using an iPod FM adapter. Here's a link to which sells the Belkin F8Z075 fro $37.49 plus shipping.
Most older head units cannot directly translate the data from MP3/MP4's so your head unit will probably display something like "UNKNOWN TITLE".
Hope this helps.
Apr 13, 2009 | JVC KDS733R Cassette Player
Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Mar 16, 2009 | JVC KD-LH810 CD Player
JVC Daisy Chain
If your autochanger has an input as well as an output connector it will be possible. The iPod adapter would have to be plugged into the changer's input, and the changer's output cable would run to the KD-G421.
This manual here from JVC shows a diagram on the middle of page 1 where an i-Pod adapter (I'm assuming you have the KS-PD100) is connected daisy-chained with an XM tuner or a DLP unit. Although it doesn't explicitly say that it would work with a CD changer, I don't think it'll be a problem as long as you have an input on the changer.
Feb 22, 2008 | JVC KD-G421 CD Player
My l/o works but my speakers running from head unit does not
You have to find the subwoofer setting on your head and turn it all the way up.
Aug 26, 2006 | JVC KD-G320 CD Player
JVC KD-SH77 CD Player Logo
35 people viewed this question
Top JVC Car Audio Receivers Experts
xxxxxx xxx
Are you a JVC Car Audio Receiver Expert? Answer questions, earn points and help others
