Question about Brother SE-270D Computerized Sewing Machine
Error Message This embroidery card cannot be used with this machine
I've used this machine for 4 years with this same memory card. Now it says it cannot be used with this machine. I've turned off and then back on and still the same message. Help????
Is it a pre-loaded card - or one you add patterns to?
If its one you add patterns to, make sure the pattern isn't too large for the machine. EG if machine does 4"x4" and you've loaded a 5"x7" pattern, try down-sizing the pattern/ breaking it up into smaller sections to load & sew
Posted on Apr 07, 2012
  • 323 Answers
SOURCE: embroidery arm
Turn off the machine, remove the carriage, check that nothing is hitting against the arm and try again.
Sewman7
Posted on May 19, 2008
joei_ph
  • 22 Answers
SOURCE: Card not not be used??
there are some memory card that has physical lock, you can see it on the card itself, but for some, you can check it if you put the card into your computer, and try right clicking on it, it would then tell you if it's lock or not.
Posted on Apr 30, 2008
bargainbox
  • 1388 Answers
SOURCE: HELLO, WOULD YOU KNOW THE
I have seen this post before, perhaps the easiest thing for you to do now, after so long, is to just ring or email Brother or one of their dealers direct.
I do know that Janome recommend no more than 256MB CF card to reduce the need for searching through vast amounts of patterns.
Posted on May 23, 2008
SOURCE: Error message on Brother SE-270D
I had the same issue a few years back but with actual symptoms of malfunctioning. I had mine fixed under warranty. The service tech told me it was a faulty circuit board. Works perfect now. I think the warranty is only for the first year to cover labor and parts. Not sure how much it would be out-of-pocket. This happened within 3 months of a brand new purchase. Hope this answered your question.
Posted on Mar 29, 2009
chrismyers67
  • 53 Answers
SOURCE: cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Posted on Jun 06, 2010
While working, the embroidery machine stopped with this message on screen.I stopped it and worked a few stitches and the stopped again with the same message. The next day I started the machine again a
Please you ask your machine service provider or embroidery Machine service mechanic. My suggestion Normally every year machine service and over oil the machine is safest way.
Feb 06, 2014 | Sewing Machines
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
Can I use the Metal Singer Class 15 bobbins in my Quantum XL1000 embroidery machine
Hi betroy,
I would suggest you stay with the plastic bobbins. but if your still
in doubt contact the singer website & ask them. me myself I would
stay with the plactic bobbins, & I've been sewing for over 30 years.
you have a very nice sewing machine.
Jun 01, 2012 | Singer Quantum XL-1000 Computerized Sewing...
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
sewingpartsonline.com
May 02, 2012 | PfaFF Creative 7570
I have a Janome Memory Craft 9500. My problem is the memory card is acting up.
yes, but since you said the machine is 7 years old, & used extensively, then
I suggest to have to machine serviced if it has not been.
it could be a computer problem or mechanical problem
Apr 11, 2012 | Janome Memory Craft 9500 Computerized...
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Can I use a Bernina card 11253 in my Simplicity Embroidery Machine SE2
Unfortunately these cards are not interchangeable due to proprietary reading/writing software. This is used by the industry to prevent customers from changing brands once they've invested in a library of embroidery designs. However there is a company that makes it possible to transfer information from one type of card to another. I haven't used their product but it may be the solution to your problem.
http://www.secretsof.com/content/2510
May 16, 2011 | Simplicity SE3 Computerized Sewing Machine
4D d-card reader/writer - seems to be installed but not working
I have been having the same problem. I was told that the 4-d software is not compatible with Windows 7.
Mar 23, 2010 | Husqvarna Designer I
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
Brother SE-270D Computerized Sewing Machine Logo
333 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
