Question about Bosch Axxis+ WFR 2460 Front Load Washer
No draining indicator says pump blocked
Washes fine ,starts humming when it should drain then tells me pump blocked. I check pump for blockage,-nothing there Whats the problem?
    Genius:
  • 1,028 Answers
Could be impeller broke off or loose on motor shaft also may be blockage in lines to or from pump and not in pump it's self
Posted on Oct 26, 2008
Can a faulty lid switch cause a washer to spin but not drain
Hum only means something is blocked mechanicaly. Not likely lid switch since it cuts power when lid is open.
Aug 14, 2014 | GE WBSE3120B Top Load Washer
Drain pump[ hums
.It is possible that lack of voltage to the pump or fault in the pump can cause the hum. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Feb 11, 2013 | Washing Machines
My Electrolux washer will not drain water or fill water, it will spin. It is also making a humming noise
You need to check for the Humming noise as this can be the indicator to the problem, if this comes from the motor then the capacitor is faulty. Failure to switch on the INLET and the DRAIN pump can be related to fault in the control panel or this can also be due to faulty electric line voltage on the outlet.. So please check this out.
Also check the inlet and drain filters for clogging as a clogged drain pump can also hum.
Jan 12, 2013 | Washing Machines
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
My samsung front loader will not start. It hums and clicks and will not start!!
The humming noise is the indication of faulty motor or motor getting blocked.If motor checks ok check for the blockage in the drain pump.But first check for the motor.Is it getting a spin.If not then it has to be replaced. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate thissolution and show your appreciation.
Aug 30, 2010 | Samsung Washing Machines
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
We have a GE Profile Harmony washer, it just ran out of warranty in September. It will not drain, it had a message to check the drain hose there might be a clog. We did this the hose was clear. There is...
Along with checking the drain hose, check the drain port from the tub, something may be blocking the drain and no able to get into the tub, or it may be sucked into the pump.
What can happen with a fully loaded machine is, for example, if a small sock happens to be at the top of the load when the spin starts, it can be flung in between the inner perforated drum and the outer. If this gets down to the drain, it may block the drain hole and stay in the drum. It also could get sucked into the drain hose and stay there, or actually get into the pump ... My vote is that it's in the pump, if the pump is humming.
Give it another look.
Dec 14, 2009 | GE WPGT9360EPL Top Load Washer
Not Spinning or Draining !
Hey there
well from what I can understand here you need to check first 2 things
1) Check that the hose that is connected to the machine is empty and that there's nothing blocking the water.
2) another possiblity is that your Pump isn't working.
saince i don't knwo the model I can't tell what kind of pump you have, if you have direct pump is should be abouve the motor, it' pretty easy to inspect it and look at it, it may be blocked from all kind of junk (coins.....) another option is that the pump blades are worn out so it's not pumping ( i don't think its your case since your washer is prettry new)
Hope this helps
Bono
Mar 24, 2008 | Washing Machines
My washing machine wont drain the water
if its making a humming sound the pump may be blocked turn the pump fan by hand to see if its free,
Mar 14, 2008 | Fisher and Paykel IWL12 Top Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
153 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
