Question about LG LMX25981ST Stainless Steel Bottom Freezer French Door Refrigerator
I have a LMX25964 ice maker is slow and bin will not fill up
It is a LMX25964ST/00 bought at Home Depot. It has started making ice very slowly and the bin never fills. There are only 2 people that use it
fridgetech
  • 473 Answers
SOURCE: ice maker LG side by side
What is the model #? Get it off the sticker inside the refrigerator side.
Posted on Oct 08, 2007
  • 210 Answers
SOURCE: LG SXS Refrigerator LSC26905 ice maker
LG has a new ice cube tray to solve this problem.
Part number is 3390JA1150A
Sgt 48
Posted on Jun 03, 2008
stradeteox
  • 88 Answers
SOURCE: Faulty ice maker
Hello. Yes, that is the correct position for the icemaker feeler arm. The updated icemaker has a longer feeler arm that hangs down a little more (thereby shutting off sooner when the ice piles up not so high).
Your water leak onto your food is from water spilling out of the front left corner of the ice tray during fill. This has also been updated with a plastic lip that keeps the water from sloshing out when filling up.
The photo shows that your ice tray appears to be unlevel and drooping in the front left corner. This happens with flex tray icemakers over time. The icetray does not fully flex back to its level posiiton. I do not feel you need to replace the entire icemaker. Repalcing just the ice tray should fix your issue.
Hope this helps, please rate my solution.
Posted on Jan 12, 2009
  • 4 Answers
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Posted on Mar 21, 2009
SOURCE: LG refrigerator model lfx25950tt ice maker not working
I had the same problem and replacing the filter solved the problem for me.
Posted on Mar 22, 2009
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
Jun 03, 2012 | Amana Refrigerators
Ice maker is leaking water and storage bin is building up with ice.
I could use a little more here on this, like the make and model and year, but if I have to guess I Would suspect the ice mold is split and the ice maker would have to be replaced, we have seen several of these that leaked up a round the head area, assuming the ice maker is level.
You could remove the ice maker from the freezer and sit it on your counter and make it level. Put a little water in the mold and watch it drip / leak.
Some models you can adjust the fill valve to slow the water down if it fills to quickly they can splash and cause a buildup
Other models there is a fill cup that needs changes out if this starts leaking.
If you can give me more info as to where it is actually leaking, we can go from there.
Aug 24, 2011 | Refrigerators
Ice maker
The Ice maker requires a connection to a water supply. If you look behind the refrigerator you should see thewater fill valve connection. It is located on the right side on the bottom. A supply line kit can be purchased at a locat home improvement store like lowes or hope depot.
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice tray not filling
Open your freezer and remove the ice bin. You will see the mechanism and the tray that fills with water to make the cubes. On the left there should be a rocker switch that turns the ice maker on and off with a green light that tells you if its on or not, under the ice cobe tray there is a small paddle that should move, give it a wiggle. On the right you will see the wire for the ice maker, make sure that it is plugged in. Once the icemaker starts working (little green light comes on) you should have ice within 24 hours. You may need to remove the ice bin and a
small plastic louvered cover above it.
Hope this helps.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not making ice
I don't recommend repair on this unit. Simple replacement. Try to find Ice maker kit @ local home depot or lowes that is same. You can buy whole kit for $50-$75.00.
Aug 28, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
An apppliance company has installed three ice makers and none of the three have worked. they may drop ice once or twice in a 24 hour period. there is also frozen water in the ice bin. Can you tell me what...
you can make ice at30/31 degrees F but ice makers do not start until it is 0/4F clean all coils and if it has a condenser fan see if it works or you may be just low on freon thumbs up
Aug 12, 2009 | Refrigerators
WE have replaced our ice maker in our Whirlpool refrigerator 4 times in the last 4 years. Our refrigerator obviously is a Whirlpool and the ice maker was ordered with the ice maker installed. WE are...
If the fill tube gets choked up with ice, (Figure S-4) it usually means that the water fill solenoid valve is leaking. The valve is not closing properly and is dribbling water. If the leakage is slow enough, water may freeze in the fill tube. Over time it will freeze the tube completely shut.
Apr 04, 2009 | Refrigerators
Faulty ice maker
Jul 01, 2008 | LG LRSC-26922 Side by Side Refrigerator
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
LG LMX25981ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
