HAVE A SUMVISION PCI TO USB & 1394 COMBO CARD. I AM RUNNING WINDOWS VISTA AND THE CARD DOES NOT SUPPORT THIS IT ONY GOES UP TO WINDOWS XP. GUY THAT I BOUGHT IT FROM SAID I CAN JUST UPDATE DRIVERS ON THE INTERNET BUT DON'T HAVE A CLUE HOW TO DO THIS. CAN ANYONE HELP
    Scholar:
  • 40 Answers
The way you do this is to take note of what the card IS, and who the maker IS and the model number which should be printed on the board. If by chance it isnt you will have to look at what other numbers you can identify it with. or you may be able to download the right drivers by identifying it by picture.
First, the maker =
http://www.sumvision.com.cn/searchResults.aspx?ptype=43
Because you have not given a model number I cannot give you the precise drivers.
How ever you asked how to find them. Go to that site, match your model number with the correct driver download for your version of windoze.
I noticed that they do not have VISTA drivers for the card I think~ you have. You may write the company for specific drivers for VISTA but I doubt they will give you any. If the XP drivers work in VISTA you are in business. If not, it may be a VISTA incomatibility problem more than anything else. Vista is very challenging. MS is actually allowing people to go back to XP at no charge until Jan something in 09.
Once you have identified and downloaded the correct drivers double click to unzip it to a folder. Go to that folder and READ any read files it has before you start and follow the directions they state. It wold be wise to set a system restore point or do a back up ( your choice) before you begin.
Thank you and good luck. *s*
Posted on Oct 26, 2008
Distorted sound output
If the motherboard supports IRQ assignment of PCI devices then YES.
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 22, 2008 | Microsoft Windows Vista Home Premium with...
Problems with the BT-ECU2FW
Thats interesting, because I bought the same Express card few days ago for my Acer Aspire 8920G, and I have the same exact problem. I thought its the problem of windows vista, but from your post it I don't think its anymore because you are running XP.
I guess I will return the card and I suggest you do the same, and try another brand Express Card.
Sep 05, 2008 | BYTECC BT-ECU2FW Expansion Module
1394 Header pin-out
http://ritmotech.com.au/onlineshop/product_info.php?cPath=21_25&products_id=57&osCsid=aeefcbb79e7dab18e3439d5d6c64cb0f
Ritmo PCI to USB + 1394 (CC-C15)
PPA USB2.0 + 1394 Combo PCI Card Model 1509
http://www.ppa-usa.com/products/usb/usb_pci/1578.htm
click on get pinouts for pdf file of card
Pinouts:
USB board is slikscreened with numbers but for reference
pin 1 ground is at top edge of board
and pin 5 plus 5v is towards gold connector edge
1. case Gnd (thick black)
2. D- (green)
3. D+ (white)
4. no connection
5. +5v (red)
Firewire: (8 pin header on board)
this board uses the 4pin firewire connection standard
NOT THE 6/9 PIN!!!! you only need to connect 4 pins
and if you have a thick case ground cable you can use it
pin 7 is towards bracket towards top edge of card
pin 8 is towards bracked towards gold edge connector
card header
5 TPB- Orange
6 TPB+ Blue
7 TPA- Red
8 TPB+ Green
3 Case Gnd Thick Black (not thin black) if you have one
(white 30vdc) and (thin black, signal Gnd)
wires are not used
pins 1 and 2 are also unused for firewire connections
please note that this card has +12v on pin 2 instead of the
30v dc that a normal firewire 6 pin connection has
Sep 01, 2008 | Televison & Video
Imstalling internal card reader
Well, installing an internal card reader without a spot on the motherboard, is a little hard to do. I would suggest buying an external card reader. They are a little cheaper, and a lot easier to setup and use, since they just connect to a USB port which all computers have.
Feb 23, 2008 | Dell Dimension 3100 PC Desktop
PCI PARALLEL CARD WINDOWS VISTA X64
There are know compatibility and driver problems with Vista. Please visit the Microsoft update website for updates and driver issues.
Feb 20, 2008 | Televison & Video
USB port malfunction?
Oh God i have the same exact problem. I run XP Pro and USB ports all malfunctioned, after tyring EVERYTHING I reloaded windows and it worked.......for about 8 months, now I'm back to I can't use my printer, storage devices ANYTHING that plugs into the USB ports. I'm at my wits end. I'm thinking of throwing the compter out the window
Jan 12, 2008 | Computers & Internet
Vista and firewire 1394?
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
Jan 05, 2008 | Canon ZR200 Mini DV Digital Camcorder
Evergreen IEEE 1394/USB fireLINE PCI Combo Card
You might need to update the NVRAM that stores the PCI configuration that is read at POST. This is done by pressing and holding the so-called CUDA switch on the MOBO for for at least 30 seconds or so. The  eraser end of a wooden pencil makes a useful tool for this ;-) It sometimes requires unplugging the computer and removing the small battery that maintains the memory so that it is completely cleared. Please check that no connections, especially memory cards, haven't been disturbed during installation as well. HTH.
Dec 09, 2007 | Evergreen (90-FLCC-AA0) Serial Adapter
Cannot retrieve video from miniDV camcorder using Adaptec Fireconnect 8300 firewire card on Windows XP Home SP2
I have found you a Manual if that is of any help? www.adaptec.com/en-US/support/firewire/FireConnect/AFW-8300/_docs/afw8300_ug_pdf.htm All I can think of is a faulty cable? Also sometime just changing the PCI slot will help?
Dec 25, 2006 | Adaptec FireConnect 8300 (2065200) Serial...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
