Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Fex831 transmission how to disassemble for transmission replacement?
  • John Park Feb 17, 2012
    Chris, thank you for your reply. I'm trying to change the entire transmission for the washer but this model is quite complicate to open up.
How to change the filter on a 2005 ford escape v6 auto transmission
There is no serviceable filter to replace on a maintenance schedule the only way to replace the filter/screen is to remove the transmission and disassemble it trust me im a former ford Trans builder
Mar 20, 2015 | 2005 Ford Escape
Is their a automatic trans filter in a 1997 honda crv and if so how do you replace
According to this parts website 1997 Honda CRV Automatic Transmission Filter this filter is internal to the transmission and requires removal and disassembly of the transmission.
Jan 06, 2015 | Honda Cars & Trucks
Am I able to get the reverse gear replaced without buying a new or secondhand gearbox.
It is possible but you may find the cost to be more than replacing the transmission. The cost could be more because of the labor involved to disassemble the transmission to replace the gearing.
Apr 25, 2014 | 1997 Volkswagen Golf
Trans.center plate spring1989fxrs low rider
Are you asking about the clutch diaphragm clutch spring?
If so, then no, you don't have to disassemble the transmission to replace.
Dec 28, 2013 | Harley Davidson Motorcycles
Replacement of transmission control solenoid
First thing you will need is a shop manual to explain how to disassemble the transmission.
Jun 30, 2012 | 2004 Cadillac Deville
Replaceing the shift lever on the transmission
If you're talking about replacing the shifter pawl shaft in the transmission, this is a major job as it not only entails the disassembly of the primary drive including the clutch but also a disassembly of the transmission. You'll need some torque wrenches ranging from 50 to 150 foot pounds that will torque in the left handed direction. You need a way to lock the primary so you can torque the sprocket shaft nut to the 150-165 foot pounds of torque that it requires. I use a locking bar designed for the bike that I'm working on. I would highly suggest that if you are going to do this job yourself, you really need to buy the service manual. The old saying "A picture is worth a thousand words" is true in this case. You can pull the trapdoor of the transmission with the two shafts and gears intact. No need to mess with the trapdoor bearings.
Good Luck
Steve
May 20, 2011 | 2005 Harley Davidson FXDWGI Dyna Wide...
Disassemble Troy-Bilt Econo-Horse Transmission (1991 Manufacture)
If you do not have a manual you can get it free at troybilt.com.
Apr 24, 2010 | Troy-Bilt Pony Garden Tiller
97 ford contour gl, info on transmission pan filter installation?
trans filter can only be replaced by taking the trans apart. absolutely not worth it.
Apr 10, 2009 | 1997 Ford Contour
Leaking tub seal, slow spin cycle
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 31, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
Feb 23, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
184 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
