Question about Frigidaire Dryers
Frigidaire LGQ1442ESO Gas dryer will not heat, code told me to replace thermistor, but still not heating ,tested flame sensor it tests fine
SOURCE: maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Posted on Apr 29, 2009
  • 3741 Answers
SOURCE: Kenmore Gas Dryer won't heat!
On the back of the dryer near the fan blower housing is a thermal fuse, if this opens up ( no continuity ) the gas burner often quits but the motor will still run. If the thermal fuse is open/bad, always clean, change, adjust the venting system and vent hood first and clean out the dryers air ducts. Sometimes it is a good idea to replace the operating thermostat at the same time.
Thermal fuse parts help link...on blower housing cover, can not be re-set, must be replaced if is open (no continuity between pins).
Posted on Jul 11, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
Posted on Aug 01, 2009
delpolito54
  • 44 Answers
SOURCE: check continuity on a flame sensor
flame sensor is closed when dark, open with the ignitor light. Thermostat is closed when cold, open when reach temperture. Ignitor is a closed circut but high resistant value, put your meter on 10k. Also to the gas valve 110volts be carefull.
Posted on Sep 01, 2009
  • 410 Answers
SOURCE: My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
Dryer runs but does not heat.
Hi.
Check the thermal fuse. The fuse can be tested reading impedance.You can replace the fuse straight away, or you can first test it using a multimeter set on Ohms. If the multimeter reads Ohms infinity when you touch the fuse contacts with the probes, then the fuse is gone. A good fuse will read zero or low impedance.
If the fuse is OK, then you can have a defective thermostat.
In the same way you test the thermostats, thermistors or cutoff located in the heating group, near to fan and element. If they are OK, then they will be conductive at room temperature and will read zero Ohms. If they are bad they read open (infinity). You need to disconnect the part's contact to test properly.
The rest depends if the dryer is electric or gas.
On electric dryers you test the heating element. The heating element is tested in the same way. Set multimeter on impedance, disconnect element, and touch contacts with multimeter probes. If it reads open, then element is gone. A good element reading depends on the specific model. Most washer-dryers, including Whirlpool and Maytag read between 10 and 20 Ohms.
With gas appliances you need to test the ignitor, then coils and then the flame sensor. The ignitor is the most common cause for the problem. Heating coils problems are also common. The flame sensor does not fail very often.
Regards.
Ginko
Sep 06, 2011 | GE Dryers
I have a Kenmore 97284810. I t was working fine until we had a power outage. Now is runs and spins but it will not heat up. The glow bar was not glowing so I replaced it. The glow bar is still not glowing....
Might be the flame sensor. if it is open the ignitor won't light off. Check this part
for continuity. Number 59. If it is open now power can get to the gas assembly. Clean out the duct work and filter housing if that puppy is blown.
When the drum temp is below 105f the control Klixon throws the power onto the gas valve assembly. The flame sensor,ignitor, and solenoids are all powered up at the same time but the solenoids won't kick in until the ignitor drops out. The flame sensor bi-metal bends with the heat from the ignitor and open the circuit to it. The solenoids then have the power to ****** open the gas valve and raw gas flows out onto the hot ignitor and lights off. The burn last only till the drum temp reaches 160f which takes not time. When that temp gets to 160 the control opens and power is removed from the gas valve assembly. This goes on throughout the drying process. So what goes wrong? Open sensor, bad ignitor, faulty solenoids that quit after working a tiny bit. Blown or tripped thermal limit. bad control tstat. And me fave: unpaid gas bill.
Aug 20, 2011 | Dryers
I have a 7yo Kenmore Elite gas dryer w/no heat. I tested all the possible culprits with my ohmmeter. I found the ignitor was not glowing so I replaced it. Now it glows but I still have no heat
The glowing if the ignitor indicates that the circuitry is good but the flame/radiant sensor is bad and/or one or both of the gas valve solenoid coils are not working. The flame/radiant sensor bypasses one the solenoid coils then when power is applied to the ignition circuit, the first coil opens the first valve, the ignitor glows and the flame/radiant sensor gets heated. It's contacts then opens when heated enough to unbypass the second coil and allow the gas to flow and be ignited.
Make sure the flame/radiant sensor is properly in place and aligned with the ignitor to allow proper heat sensing. You may check the continuity between the sensor's contact terminals as the ignitor glows. At first, the terminals should read close (zero resistance) and then open (infinite resistance) after about 30 seconds or so. If this is not the case, the sensor is not working and must be replaced.
The solenoid coils, one with 2 prongs and the other has 3, sitting on top of the gas valves must be both replaced if the flame/radiant sensor turns out good. But before doing so, make sure to run a test with the dryer completely assembled because sometimes the gas do not ignite when the dryer's cabinet is open. This is to prevent unnecessary replacement of the coils.
Feel free to update us about the result and if you need further advice.
Jun 17, 2011 | Kenmore Dryers
Nov 26, 2009 | Frigidaire AEQ6000ES Electric Dryer
Dryer runs fine but does not heat
Check that the pilot light is lit and flame kicks on when dryer is activated. If no flame, then check gas valve. If only pilot remains lit but does not increase when dryer is activated, then you could have a bad coupler or sensor or circuit problem which would have to be tested with a voltmeter and/or test light.
Nov 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Gas dryer won't heat up
The ignitor can glow and still be defective.
Take a volt meter and check for power at the gas valve while calling for heat.
If you have voltage, replace the coils again.
No voltage, replace the ignitor and flame sensor.
Mar 08, 2009 | Frigidaire Dryers
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Feb 04, 2009 | Dryers
No heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Jul 25, 2008 | Amana ALG331RAW Gas Dryer
Dryers Logo
127 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
