Question about Frigidaire Affinity ATF7000ES Front Load Washer
Pau 33 code what does it mean
I changed out the front door due to a broken hindge and replaced it but it still doesn t work .You press start it makes a clicking sound and PAU 33 comes on . What does this mean?
2 Suggested Answers
SOURCE: 2yr old daughter hit some buttons now it won't - pau 33 pau 33
did you get this fixed? how? my 2 year old son did same thing.
Posted on Apr 24, 2010
I have a Frigidaire front load washer #ATF6000SF1 and need to reset the PAU and E41 error code. I cannot get the unit into diagnostic mode to accomplish this. How can I reset this code?
I appreciate your post, Josh Orenstein!
From my understanding your Frigidaire washer is displaying "PAU" and "E41". "PAU" normally displays when there is an interruption to the cycle and "E41" means the main control board thinks the door switch is open. Either code can display due to a faulty door latch assembly, door strike, or main control board. You can attempt to perform a factory reset by holding down the Start/Pause button and Select button until a signal sounds. Also review the door latch and strike to see if there is any visible damage that could cause a short within the components. If there is no visible damage you may want to consult with a technician for proper diagnosis and repair of your washer. Hope this information is helpful to some degree. -Matt
Dec 07, 2014 | Frigidaire Washing Machines
Pau 12 flashing frigidaire
Hey friend, thanks for your inquiry!
I see off your post your Frigidaire washer is showing a "PAU 12" code. Typically "PAU" stands for pause which means the cycle has been interrupted. I would open and close the door to assure that there is a proper connection between the door strike and door latch. If you check that and still receive the "PAU" I would recommend a reset, which can be done by flipping the household circuit breaker off for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 07, 2014 | Frigidaire Washing Machines
Frigidaire front loading washer will not start will not stat, I get a PAU or ERR message, tried resetting by unplugging for an hour, removed and cleaned soap dispenser, and checked door for proper closure....
Thank you for your question, Friend.
If you are still receiving an error code PAU after resetting your washer, then the door of your washer is probably not securely latched or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume cycle. If the issue persists, then your washer could possibly have a faulty door latch, door strike or experiencing a communication error with the control board. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts. Best - Z
Aug 07, 2014 | Frigidaire GLTF2940ES Front Load Washer
Hi Mr. Barry Coates, I have frigidaire ATF 6700FS front load washer. I am having problem with error code E41 and all time it shows me PAU. I tried all the solution on this site but nothing works. Could...
E41 - Control board thinks the door switch is open.
PAU means PAUSE in the cycle; if you are try all methods, I assume that the control panel needs to be replaced.
Check in this link your Control Board Replacement
Hope helps.
Oct 12, 2011 | Frigidaire ATF6700FS Front Load Washer
Won't start led read pau then 45
Hi!!
The error code 45 means control board communications problem. And Pau shows when the cycle was interrupted, try disconnecting the unit form the wall outlet, wait for about 10 secs. and plug it back in. If this do not clear the error code. Replace Board.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Frigidaire Affinity ATF7000E Front Load...
My LG washer keeps displaying DE and makes door clicking noise and if it unlocking the door and will not start a cycle. We have bought a new door sensor, and control panel. What else can it be?
Hi dear.According to your explanation,MAIN PWB ASSEMBLY is faulty.Not the door lock or control panel.However you can try this & see if it's works.I hope that helps.Thanks. Does the spring of Latch Hook actuate?If No:Replace door assembly
Is there clicking sound once or twice when the
START/PAUSE button is pressed to start the cycle? If No:Check the DOOR SWITCH
ASSEMBLY Connector and
MAIN PWB ASSEMBLY
(Red 4 pin and white 4 pin
connector (1)).
Is DOOR SWITCH ASSEMBLY broken?If Yes:Replace the DOOR
SWITCH ASSEMBLY
Aug 21, 2010 | LG WM-2277HW Front Load Washer
Dec 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Can't open door
inspect the door hindge pins and busings it sounds like they are getting worn out and maybe due for replacement. also look and see if the spring in the hindge is still their. if all is well have the door adjusted properly to repair your problem.
Mar 22, 2009 | 1996 Chevrolet Tahoe
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
