Diplomat APM 8703/2 washer dryer - when on any wash cycle the machine clicks fills with water and wont empty have to move dial by hand
When the machine is on a wash cycle the machine fills with water but no longer goes through the cycle it keeps clicking as if dial moving but fills with water and does nto empty. dial has to be moved by hand sometimes through most of on part of cycle
  • 641 Answers
SOURCE: washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Posted on Jul 26, 2007
Jimster
  • 240 Answers
SOURCE: Hoover 600M washing machine cycle issue
Sounds like you may have a timer problem. You might be able to pick one up at a appliance parts center. Most of the time, they can be pretty pricey item, if you can even get one for older models. Check EBAY as well, sometimes you can find hard to find parts for pretty cheap. Replacing the timer shouldnt be that hard. UNPLUG the unit, remove the console, which should be held on by screws, the remove and replace one wire at a time back to the timer. Use caution when removing the timer knob, you dont want to crack it. Most knobs remove by unscrewing to the left.
Posted on Sep 05, 2007
yalmer
  • 549 Answers
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Posted on Mar 04, 2008
Master_Tech
  • 770 Answers
SOURCE: washing machine is filling with
have you checked the lid switch
Posted on Jul 09, 2008
  • 1462 Answers
SOURCE: Diplomat washer drier
all you have to do is:
select half load
set drier timer to required time. set main timer to dry program
i suspect you are not pressing half load button - this is essential
Posted on Jul 20, 2008
Diplomat washing machine
Try Sliding the Soap Dispenser Drawer Lock to the RIGHT and then pull straight back... It is located under the handle
Mar 03, 2014 | Washing Machines
Washer won't drain, it is a Diplomat washer dryer model HJA 8703, is there a filter on the machine?
there is a filter down on the bottom right hand side. twist anti clockwise but drain it first if you can. If not lean it back a bit and put a bowl under the filter
Mar 29, 2010 | Washing Machines
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM1200 washing machine wont advance at certain stages
there is a little motor in the selector switch that moves the dial around.  This little motor is defective and needs replacement.  Sometimes it's sold separately and sometimes you need the whole timer.
Apr 01, 2009 | Whirlpool AWM6120 Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Hotpoint WD62 Drum wont turn
tilt the machine backwards. with a multimeter, check continuity across the brushes - if open circuit then brushes need to be replaced
Oct 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Won't do anything
no, you need a lid switch. when the switch fails it wont do anything but fill. replace switch to fix problem
Nov 18, 2007 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
105 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
