Question about Motorola Mobility RAZR V3c Cellular Phone
Service I was sitting down and then I herd my service tone drop, Now I can't even get service to my network and my family has the same phone and mine is the only one that lost service. My phone is a motorola v3c razr. any solutions
    Brigadier General:
  • 7,752 Answers
Hopefully you have tried the network search to put the service band back if not then do so...
menu/settings/network...then select manual search and change the band to the MHZ your carrier use
Posted on Nov 01, 2008
My lg Venus can't find service in places it usually does. But rest of my familys phones still do
If your family is using a different phone with the same network then it is possible that your LG phone has a low transmission. If your family is having a different network then you must check your phone with this network as it might be giving a better spread.
Normally it is not a big defect if the range is down as with a weak range you may get interuppted service.Also the shielding to prevent microwave in the phone reduces the range but this could be better for your health. hence if your phone give you better quality of talk, i would advice you to ignore this. but If you think that the phone is very poor then you will need to opne out the phone, check for any moisture,bad connectivity in the area of the antennae. clean the set and be lucky if this work out better. If not before you come to a final decision checck this with a different network. Hope you get this right. good day
Jun 23, 2010 | LG Venus VX8800 Cellular Phone
Having problems with calls coming through on the blackberry pearl, I am sitting right next to the phone and never hear or even see the call come in. What can I do to change this?
In this case please follow the steps:-
1) Go to profile.
2) Scroll down and Select Advanced.
3) Press Menu key.
4) Select Edit.
5) Scroll down and Select Phone.
6) Select out of Holster, Select the Option which you like and select the tone as well.
7) Scroll down and Select Volume, Keep it High.
After doing all this changes check the ring tone in your Handheld it will work, Incase still if it is not working there might be a problem with the Speaker you need to walk into the service center.
I hope I was able to help you.
Thank you for using Fixya.
Nov 16, 2009 | RIM BlackBerry Pearl 8100
Blackberry 7290 no service suddenly
Try turning the radio off, power down adn then back on.
Got to Network, diable automatic and select your netwrok provider.
May 27, 2009 | RIM BlackBerry 7290
No dial tone
Have you replaced the phone cord to the wall? if not start here, if the base has not been dropped or wet, try resetting it.
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
Hope this is of some help.
Ed
May 05, 2009 | Lands Phones
How do I enable family safety service
Services are located in the control panel. Most likely this is where the Family Safety service is located. The easiest way to locate the services is to navigate to Start>Run. Once the dialog opens, type in: services.msc
Now press OK. The services window should open. Look for your service (family safety) inside the list of available services. Once found, right-click it and go to, "properties". Inside this dialog box find the only available drop-down menu selecting the, "Startup type." Change the service to, "Automatic" from within this drop-down menu. Now press, "Apply." Afterward press the, "Start" button (within the service window) to start the family safety service. After the service starts, press OK to exit the dialog screen.
If for some reason the service won't start, copy the error message and post it here.
Let me know how it turns out or if I can assist you further.
Apr 25, 2009 | Dell Computers & Internet
Nokia 1600 is dead how to repair it
If your phone appears to have problems with power, the problem may be with the phone, the battery, or the charger.
  • The first thing to try is to connect the phone to its charger. Connect the charger to a power source, wait for a few moments, and then try to turn the phone on.
If the phone still won't power on, please perform the following checks:
  • Fully charge the battery according to the instructions presented in the user guide.
  • Remove and re-insert the battery according to the instructions presented in the user guide.
  • Check that you are using a Nokia battery and charger compatible with your phone model. You can check compatibility from the Battery Compatibility Chart and Charger Compatibility Chart.
  • If you have access to another battery and charger of the same type as yours, try substituting them to determine if the issue is with the phone, the battery, or the charger.
If you are unable to test your phone or it still won't power on, please bring it to the nearest Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone is always low on power
If your phone appears to have problems retaining power, the problem may be with the phone, the battery, or the charger.
  • Check that you are using an original Nokia battery and charger compatible with your phone model from the Battery Compatibility Chart and Charger Compatibility Chart. If your battery features a hologram label, you can authenticate that the battery is an original Nokia product with our Check Your Battery service.
  • Even high-quality batteries like Nokia's will eventually lose power retention capacity. If it is time to replace your battery with a new one, be sure to purchase an original Nokia battery from an authorized Nokia dealer.
If you are unable to test your phone, charger, or battery or need further assistance, please bring them to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My calls break up/are dropped
Dropped calls or low sound quality during calls can result from low signal strength or momentary gaps in network coverage, either at your end or the other end of the connection.
In most cases, your operator or service provider is the best source of assistance with issues regarding signal strength.
  • Signal strength is indicated by the signal indicators at the left side of the phone's display, these indicators move up as the strength of the signal increases and down as the signal decreases.
  • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
If you continuously experience low signal strength in a certain area, it may be that network coverage is insufficient there. Your operator or service provider can provide you with more information on network coverage.
If you believe that the problem may be with your phone instead of the network, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't ring
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
If your phone still won't ring, please bring it to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
My phone won't send/receive messages
Email, text messaging, and multimedia/picture messaging must be supported by your contract with your operator or service provider. In addition, your phone must support these features and have the correct settings.
  • Check the types of messaging supported by your phone model. You can find this information in the user guide. Look for the terms SMS for text messaging and MMS for multimedia (picture/audio) messaging.
  • Contact your operator or service provider to check that email, text messaging, and/or multimedia (picture) messaging are included in your service contract. Also verify that roaming is supported when you are not within your home network.
  • Install messaging settings for your phone. You can download settings for free from our Setting service.
If you are still unable to send or receive messages, please bring your phone to a Nokia Care point for inspection. You can find Care point addresses from the drop-down menu to the right.
I want to recycle my phone and accessories
Just drop of your old mobile phone and accessories at any Nokia Care point. Nokia will send the old products to closest Nokia approved recycling company. Mobile phone recycling leads to both material and energy recovery from old devices, and helps ensure the proper disposal of harmful substances.
Apr 24, 2009 | Nokia 1600 Cellular Phone
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
Loss of signal alarm
Go to settings, then scroll to network and turn the service tone, Network jingle off call drop tone OFF
Hope this helps
Jul 19, 2008 | Motorola Mobility RAZR V3
Motorola k1 loses network constantly even when still
I think with this model phone motorola is having network problems.....so take it back to the store you bought it from.
May 30, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Tone arm is hard to move and when it's placed on a record the needle sticks at on spot on the record. the same needle and record plays fine on other technics 1200 mk5. seems like the arm has resistance in...
You have a bad tone arm. I have the same tables. You need to get it repaired if under warrenty. Or there is a service manaul online you can get from ebay. Service center for our tables is Panasonic.
I had the same problem on mine. But while it is in the shop they recalibarte it
Feb 13, 2008 | Technics SL-1200 Turntable
Motorola Mobility RAZR V3c Cellular Phone Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
