Question about Water Heaters
How to reset RD628
Flashing light above water temp dial....where is reset button??
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: NEED TO RAISE TEMP ON WATER HEATER. RHEEM 82V80-2
No.
Posted on Jan 05, 2010
RHEEM RTGL 74 XP FLASHING 80 AND CL
I know this is late, but I just went through this problem right now, or rather just a few minutes ago, after finishing the installation.
What worked was holding the up and down arrows together, this is usually what resets other electronics. Well, it worked. It caused the unit to reset and everything started working properly.
Again, while I know this is a late answer for you, I hope it helps others that were looking for a solution and could not find one, like myself tonight.
Sep 14, 2012 | Rheem Tankless Hot Water Heater...
How to reset filter indicator on luxpro psp511lca
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
Jul 17, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Code 991 continues to show.. will not clear... how do we clear that code???
to clear the 991 Takagi code, simultaneously press the bottom 2 grey buttons of the four just to the left of the flashing LED light. When the LED stops flashing, release and then press the reset button on the black panel about 8 inches above that
Jan 17, 2011 | RTO Takagi T-M1 Mobius Gas Tankless Water...
Rheem 21V40-38 Gas - pilot light is on but when i turn knob to hot it does not do anything
Is the pilot knob turned to the "On" position? If the knob and temp dial are set in the correct position, you may have a recalled wtr htr which requires a retrofit "reset" button that needs to be installed. Call the manufacturer;s phone # that's printed on the side of the water heater and give them the model # and serial # and find out.
Douglas
Aug 24, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have an AE 125, I have to reset the third tank (press the little black button on the top) about every two weeks. Any idea why this occurs?
Thermal overload. The unit can produce temps of 140 deg. F. It should never be set that high. I am sure the temperature dial is set at max and you are cooking the coil in the copper element. The mineral in your water has likely damaged the element. You can try turning down the temp to about 115 deg f (use a meat thermometer at the faucet). Good Luck.
Mar 11, 2010 | Bosch PowerStar AE125 AE125 Whole House...
How do i use the reset button to turn the hot water to star heating again?
turn the dial to pilot and push and hold down red button while you light the pilot located inside water heater beside burner, keep holding button down after pilot is lit for about 1 minute. If you let go and pilot goes out repeat above steps and make sure pilot flame is heating up the thermal couple. If that fails replace themal couple.
Oct 24, 2009 | Rheem Water Heaters
I have a electric whirlpool 50 gal. energy saver water heater that is 3 months old. It keeps shutting off so i called whirlpool and sears came out and replaced the energy smart box on top. now it is...
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Jun 25, 2009 | Water Heaters
High water temp
Have you done a reset on the board?
The reset function is used to restart the Temperature Control System after an error condition has been detected and
corrected.
Reset the control by pushing the red reset button on the controller. After a reset, the control performs self diagnostics
before normal operations begin. This takes approximately 10 minutes.
Then do the following if the flashes don't stop.
1. Make sure upper and lower access doors and insulation are
properly in place
2. Check element circuits for resistance of 5 - 25 ohms
3. Replace element if necessary and reset control system
Mar 21, 2009 | Water Heaters
Fault light flashing 1 flash per second
Prior to writing the above fault I had asked the owner to turn the boiler temp controller , for the heating side, down just a fraction . I was phoned this morning to tell me that the boiler had stayed on allnight with no fault light . After consulting with the plumber who fitted the system it appears that there might not be a room stat ,
Nov 30, 2008 | Bosch Water Heaters
Water Heaters Logo
22 people viewed this question
Top Water Heaters Experts
Donni Steen
Paul Carew
Are you a Water Heater Expert? Answer questions, earn points and help others
