Question about KitchenAid KESC307 Electric Kitchen Range
KitchenAid KESH307HBL4 Electric smooth top
My start button on the touch pad of my KitchenAid Superba Model # KESH307HBL4 does not work. The only thing I found when I pulled off the control panel and checked out the curcuit board underneath was a part # K-5 Bake looks like it might be fried. Everything else on the touch pad seems to work. Do you have to replace the entire curcuit board? Or the touch pad? Help!
  • Anonymous Feb 18, 2009
    We have the KESH307HBL4 smooth top slide-in electric range.
    We have just purchased the control panel, does not work..  Checked the coils and they have an open circuit so they are not fried.  What else can it be? This is a 7 year old range, not ready to toss it.
    DC
    President:
  • KitchenAid Master
  • 2,651 Answers
That a tough one, when you press the start do you here a tione indicating that you depressed it??? if so then i would say your getting the power from the switch, and the burnt relay is the issue, but if theres no audio indication of hitting the button id replace both
Posted on Oct 26, 2008
Kitchenaid Superba Gas oven and cooktop. I frequently get a F2: E1 code, which goes away when I reset the fuse. Also, the 1, 4, and 7 touch pads don't work but all others do.
You have a bad touchpad. The ribbon cable is a failure point on all of these whirlpool built ovens. Enter the model number in at this link and see if they make a replacement keypad for your oven: Introducing the Ledgestone Technologies Touchpad
Aug 25, 2016 | KitchenAid Architect II Superba EQ Series...
Error code F2E4 On model KESC307 Kitchenaid Superba?
Tech sheet doesn't say much says noise interference at keypad says press cancel button and remove electronic noise interference if code returns replace key pad assembly not a common code if you chose to replace the keypad make sure it comes with instructions have changed two has to be programmed
Feb 14, 2015 | KitchenAid KESC307 Electric Kitchen Range
I have a kitchenaid KEMc308 Superba Electric oven and micowave combo. Just had the light &door spring replace. Now, it gives code F2 E0 for 60 second and then give code F2 E1. I checked the key...
If you're searching for an obsolete keypad for a Kitchenaid Oven/Microwave unit, FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order.
Feb 02, 2015 | KitchenAid Ovens
What does optim ice button mean
OptimIce
Feature
The OptimIce feature assists with temporary periods of heavy
ice use by increasing ice production.
Press the OptimIce feature touch pad to set the freezer to
the lowest temperature setting. Press the OptimIce touch pad again to return to the normal freezer set point.
NOTE: The OptimIce feature will automatically shut off in
approximately 24 hours
Aug 28, 2013 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba kgsc308lssc keypad not working
Hello Ron,
On that touch pad not working do any button at all work?? its not a uncommon thing for the touch pad to quit working,in some case its just a matter of making sure the plug on it has a good connection where it plugs into the control board. If certain button work while others don't its a sign that the control board itself is good and the problem lies within the touch pad and it would need to be replaced. It may possible as to clean the connection of the ribbon cable on the touch pad by using a pencil eraser and try cleaning the ends of the ribbon cable,again if that doesn't work the touch pad would need need to be replaced . On that model the touch pad is integrated onto the control console and the part number for it is 9782418CB just so ya know its pricey (over $200 )
Good luck,GENE
Oct 06, 2011 | KitchenAid KESC307 Electric Kitchen Range
My KitchenAid Superba oven is not heating. Code F2- E5. thank you
Hello and sorry to hear about your problem. The code you have given, will have this problem. I suggest you contact a service person.
F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
I have tried to help you. Please help me by Vote/Rate the response. Thanks and good luck
Dec 20, 2010 | KitchenAid KEBC107 Electric Single Oven
Magic chef smooth top electric free standing oven temperature
Most likely a bad temperature sensor if the bake element is coming on and not reaching temperature.
The temperature sensor is in the back wall of the oven up high on the right or left side depending upon your model number. It is about 3 inches long and about the size of a thin pencil. It removes from the inside of the oven.
Nov 19, 2009 | Kitchen Ranges
Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
KitchenAid KESC307 Electric Kitchen Range Logo
608 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
