I have a fujitsu siemens lifebook ah531 can you tell me how to get to the webcam
hokuwho
  • 306 Answers
SOURCE: win 2000 on fujitsu siemens lifebook b-series
  • Boot to the xp cd
  • After the setup installs then it will ask if you want to install xp, repair or install to another partition.
  • Choose install and the install program will say that it is inspecting and looking for previous Windows.
  • The dialogue will now say that a previous Windows is installed and to choose whether you wish to install on the same partition -you do not, delete that partition -you do. I think it is "D" to delete, then "L" on the next Window.
  • When you see the next screen it will list the partitions. Notice the "unpartitioned" disk space -that is where you want to install the new Windows.
  • It should be all or most of your hard drive space. If there are other partitions delete those as well unless there is a relatively small partition, say 4 or 8 gigabytes partition that may have information stored for the hard drive itself to use for it's own purposes.
  • When you have the unpartitioned space maximized by deleting the existing Windows you be asked if you want to format the drive in NTFS, Fat32 or leave intact or quick format.
  • Choose NTFS, full format (slow) and let the format begin.
  • When complete it will reboot automatically or you can reboot yourself.
  • After reboot the Windows driver load and inspection will repeat but this time you will have a formatted partition. Choose that for your new install of Windows. After that is complete reboot to your hard drive, not the cd. You can remove the cd if you want to make sure you are booting to the hard drive but the new Windows installation may ask that you reinsert the cd as it loads drivers and so on. At this point have any other cds available for installing drivers for printers, video cards, network adaptors and so on. If you do not have them then download the Windows 2000 drivers to a thumb drive or cd before you do this install.
  • Windows has program compatibility program that inspects or lists what devices might not be compatible with Windows 2000. Also the manufacturer can tell you what Windows versions they can support. Here is a comprehensive list of Microsoft downloads for Windows 2000. Make sure that you have service pack 4 downloaded to cd or thumbdrive.
  • http://www.microsoft.com/downloads/results.aspx?pocId=38DF6AB1-13D4-409C-966D-CBE61F040027&freetext=2000&DisplayLang=en
  • Take you time and let me know if there are any problems encountered. I am certified for Windows 2000 Pro OS and networking. ~Steve Medley
Posted on Nov 10, 2008
  • 84 Answers
SOURCE: Reset the BIOS password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on May 19, 2009
  • 39 Answers
SOURCE: My Fujitu Lifebook c1020 display is bad and needs swapping. I need a repair maual.
its pretty simple to change the screen on this computer, and you dont really need a service manual (i dont even think you will find one for that)
the way you do it is remove the rubber "dots" around the screen, there should be atleast 4.
when they are out, and you have removed the hidden screws, you can take of the frontbezel around the screen.
when the bezel is off you might need to loosen or remove 1 of the 2 screwes on each side at the bottom hinge.
the screen itself is fastened to the hinge with 2-4 screws on each side of the screen. remove them, take out the flat/wide cable on the backside, and disconnect it from the 5-6cm long printbord.
reverse the process when you put in the new screeen.
Posted on May 29, 2009
Schmead10
  • 650 Answers
SOURCE: i have a fujitsu siemens
go here pick your 8010 in the E series slot then pick your O/S hope this works
Posted on Dec 05, 2010
SOURCE: i want to reset fujitsu
i want fujitsu siemans lifebook bios paasword
plssss............
Posted on Dec 19, 2010
I have fujitsu lifebook Ah531 and using windows 7 x86 Ultimate version.i want wifi drivers because i have download wirless drivers but they are not working plz give me sloution
Here you go http://www.odrivers.com/2012/10/fujitsu-lifebook-ah531-drivers-win7-64.html . These are drivers for your lifebook and if you scroll down you'll see "Wi-Fi / Wireless LAN, Intel" and right below it there's a "Download" button.
Aug 03, 2013 | Fujitsu LifeBook AH531
Fujitsu siemens amilo pro says wireless internet is connected but wont connect
I would start with restarting the wireless router and the modem for your internet connection. If that doesn't fix the problem then I would look at software issues.
Feb 08, 2013 | Fujitsu LifeBook AH531
My Fujitsu Lifebook AH531 won't start up all all, as if the battery is dead. I've bought a new charger and the problem remains. Can anyone help please.
you need to find out if you are getting voltage to motherboard may be a bad jack if you do not have the tools bring to a repair shop
Jan 19, 2013 | Fujitsu LifeBook AH531
LIFEBOOK AH531 webcam not working
I don't know what program you are trying to use. Does it work on skype? Or a similar program. I would suggest using a free service to test the webcam.
Nov 12, 2012 | Fujitsu LifeBook AH531
Webcam is not work
Is it listed in Device Manager? Is it a Infernal or External? I looked at the specs for your laptop,Fujitsu AH531. The webcam software should be CyberLink YouCam, open the software, does it work in CyberLink? If not go to Device Manager> Imaging Devices to verify that the webcam is configured and working properly.
Nov 04, 2012 | Fujitsu LifeBook AH531
Where is the wireless switch located on the Fujitsu Lifebook A series model AH531?
I'm not sure where the switch is but to enable the wireless connection, you could go to the control panel>network and internet, in the left hand menu choose, Change adapter settings, right click on your wireless network connection and click enable.
Mar 16, 2012 | Fujitsu LifeBook AH531
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
