Question about Dell 2230d Laser Printer
Dell 2230d Laser Printer fuser - Dell 2230d Laser Printer
Corysf62
  • 188 Answers
SOURCE: How to Replace Dell Fuser?
Hi Paul,
If this is a 5100, then the replacement of the fuser is quite simple.
1) Before removing the fuser:
  • Disconnect the A/C power cable from the back of the system.
  • Press the right side latch button, and then rotate open the outer duplex assembly.
caution.gif CAUTION: The fuser reaches extremely high temperatures during operation. Allow for adequate cooling time after the printer is powered off, before removing the fuser.
2) Lift the two fuser assembly locking levers.
3) Grasp the two fuser handles, and then lift the fuser out of the chassis.
Posted on Oct 22, 2008
  • 5 Answers
SOURCE: Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
  • 65 Answers
SOURCE: Dell 1110 Laser Printer Fuser Error after
I would if it will print I would try a laser printer cleaning kit canbe found at any office supply like office max or staples
Posted on Jan 09, 2010
SOURCE: My Dell 5110CN printer is printing a double image
I am having the same problem, and I am using the original toner cartridges that were supplied with the printer, so yes, they are genuine Dell toner cartridges.
Posted on Jan 31, 2010
brett207
  • 231 Answers
SOURCE: Dell printer will not print. Receiving message: fuser error
Fuser error usually means that the heater element has blown, or is not functioning properly.
The device will usually lock itself out to prevent any risk of overheating and causing a fire
You will need a technician to fix this
Posted on Feb 02, 2010
Solid red ready light on DELL 2230d printer
The Red light on this printer means one of the things listed below are at fault
The printer is experiencing an error, such as open cover, empty paper, not installed waste toner container, or full waste toner container. • The printer is experiencing a service required error, such as LSU error, fuser error, or ITB error
Aug 14, 2014 | Dell 2230d Laser Printer
What could be the problem with my printer? The toner button keeps flashing. I already replaced the ink cartridge on the printer, but the only thing the printer will allow me to print is the device...
Hi
If you have done more that 30,000 prints then I would think the flashing light means you need to replace the drum in the laser printer
Cliff Cook
MCP
Aug 03, 2014 | Dell 2230d Laser Printer
How to replace fuser in Dell 1135N printer
Contact nearest Dell printer technician Center or Dell customer service center. If not available then visit this link i hope solved your issues.
Read More...Dell Printer Support
Thanks,
Jul 23, 2014 | Dell 1135n AllInOne Laser Printer
WHAT THE SYMBOLS MEAN
From left to right:
(Lights)
Exclamation point: Error
Weird Monitor beat symbol: Jam
Paper: Out of paper
Toner (Triangle leading down to dot pyramid): Toner refill
Lightbulb: ready
(buttons)
Greenish Play button (square with triangle): Continue
Red button with x: Stop/Cancel
Dell 2230 User Guide Page 1
Mar 27, 2013 | Dell 2230d Laser Printer
Reset fuser reading in window display what should I do
Open the fuser door and pull the fuser unit out, top of printer or top rear. Should see 2 oval looking handles I believe they are blue, grab the handles and pull the fuser should pull straight out. Then re-seat it back in to printer. And by the way do this procedure while the unit is sill turned on.
Jul 31, 2012 | Dell 2130cn Laser Printer
Replaced fuser on Dell 5110cn printer. How do I reset?
There is no way to reset the Dell 5110 fuser 310-8729 (also known as TD218 and other numbers)
The connector in the fuser holds the page count. If you printed 200 pages on a fuser and moved it to another printer, you'd see it follow the fuser.
You may have put a non-compatible fuser, or it may be depleted already, or there is a circuit board problem.
Whit
Item, Inc.
Sep 17, 2010 | Dell 5110cn Laser Printer
Feb 02, 2010 | Dell 1110 Laser Printer
Jan 09, 2010 | Dell 1110 Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Dell 2230d Laser Printer Logo
208 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
