Question about Whirlpool Duet GHW9150P Front Load Washer
How do i reset my whirlpool duet
Is there a "reset" button on the Whirlpool Duet washer? I have this awesome front loader but it had an F11 code on it and so we had a someone come fix it. After finding a pen and a green plastic army man (yikes) in the bottom of the washer unit, it was "fixed" and all should have worked again. Unfortunately, although I know it was fixed, it still is doing the same code F11 and the cycle won't go for more than 30 seconds before stopping and showing this code. SO my question is: IS there a reset button that will cancel the code and allow it to work? I can't find it any where in the manual.
Master_Tech
  • 770 Answers
SOURCE: whirlpool duet washer
F11=Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit
(MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control
Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
F28= No such Code could be out of the fact you have a F11
Posted on Feb 18, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet Washer
"F11" is a serial communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU), or interconnecting wiring. In a nutshell, the CCU, (which is the main computer board for the washer) has more than likely failed. You can try disconnecting the connectors and plugging them back in on the CCU, but I haven't had much luck with that remedy. You will need to UNPLUG the washer & take the washer top off by removing the three screws in the back to gain access to it. Once removed, slide the top back and then lift up. The CCU is located directly behind the wash tub.
If you cannot get the fault to clear and wish to repair this yourself, you can find the part at repairclinic.com. Just type in your complete model number and look for item number 1176592. The part lists for about $157. Searspartsdirect.com also has the part for much more, but offers informative troubleshooting diagrams. The CCU can be found under the "Control Panel Parts" heading as item number 15 (part #8182695). If you wish to do some comparative pricing of your own, use the part number provided by the Sears website.
If the washer still carries a warranty, this would be covered. Doublecheck with the manufacturer on how long some parts are covered. Some of the electronics and mechanical parts are covered beyond the one-year limited warranty that generally comes with your appliance.
I know this may be discouraging news, but you can repair this yourself and avoid labor costs. It may seem expensive, but considering how much these washers cost (I know, because I own one), it may be worth the effort. I hope this helps you. Post back if you have further questions or need instructions.
Posted on May 08, 2008
SOURCE: Duet HT F11 fault code
F11 is a communtication problem between the main control board and the motor control board . Check the wire harness connectors between those units and the motor.
Posted on Jul 10, 2008
CMV9
  • 594 Answers
SOURCE: whirlpool duet wahsher
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Posted on Aug 18, 2008
  • 63 Answers
SOURCE: Whirlpool Duet Error Code F11
its your ccu board under top in back easy to change about 300.00 that is f 11 code "plz"
Posted on Nov 15, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    My dryer says "control locked".
    Hello & Welcome to FixYa
    This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
    Kevin
    Aug 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    How do i reset front panel on my whirlpool washer front load duet
    Hi
    Its a simple procedure to reset the Whirlpool Duet front load. Please press and hold the END OF CYCLE button for 15 seconds to reset. Please get back to me if you have any other questions.
    Kevin
    Nov 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Whirlpool Duet front loader Washer approximately 6 years old. The control lock is on and I can't start the washer. How do I resolve this problem.
    This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
    This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
    Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
    Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
    These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
    NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
    If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
    Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
    Oct 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
    NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    F-02 error code on whirlpool front loader duet
    http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
    May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Front load whirlpool duet washing machine controle locked light is on how to reset it?
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&###%%
    May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    I have a Whirlpool Duet front loading HE Washer. My controls are locked how do I reset? I have tried everything I can think of. Any help will be greatly appreciated. Thanks
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^%%$$
    Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Need to reset whirlpool duet front load washer
    How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
    Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    182 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
